How to exaggerate elevation in scene
4055
12-14-2015 07:24 AM
LanceCrumbliss
Is there a way to exaggerate the elevation values in a scene?
ChrisSmith7
Honored Contributor
I perused the API v4 and didn't find anything on vertical exaggeration. Are you not able to set z-factor prior to publishing the scene?
Looking at this sample:
https://developers.arcgis.com/javascript/beta/sample-code/sandbox/sandbox.html?sample=layers-scenela...
I see a mention of the z-factor in the service:
https://scene.arcgis.com/arcgis/rest/services/Hosted/Buildings_Brest/SceneServer/layers/0/
LanceCrumbliss
What I'm hoping for is a way to set/adjust it on the client.  It seems like a logical property to be able to change, especially in areas where elevation changes are relatively minor and an exaggeration would help make them stand out.  I understand it may be possible at the service level, but honestly it just seems like something a user would want to be able to control.
ChrisSmith7
Honored Contributor
It does seem like something that should be available to the client. I checked the SceneLayer class - the metadata is excluding ZFactor...
declaredClass : "esri.layers.SceneLayer",
classMetadata : {
  reader : {
  add : "copyright initialExtent fullExtent geometryType renderer labelingInfo cachedDrawingInfo spatialReference objectIdField popupTemplate".split(" "),
  exclude : "id version name href ZFactor alias description copyrightText popupInfo".split(" ")
LanceCrumbliss
Interesting...I REALLY hope this is something that will be adjustable in the final version.  Makes too much sense.  And frankly, I think a user would expect it, especially savvy Google Earth users.
