How to dynamically change display field for suggestions in search widget?
1160
08-22-2024 12:59 AM
AMostafaH
I got a problem in search widget which is when searching the displayed field for the suggestions does not match the field matched with search term.
Is there a way to handle it using displayField or suggestionTemplate property?
I'm using version 4.28.
Thanks in advance.
MatthewDriscoll
Make sure to change includeDefaultSources to false.  I also make sure my sources searchFields, outFields, and diplayField are all the same.
const searchWidget = new Search({
      view: theView,
      searchAllEnabled: true,
      maxResults: 10000000,
      maxSuggestions: 10000000,
      title: "Quick Parcel Search",
      label: "Quick Parcel Search",
      includeDefaultSources: false,
      locationEnabled: false,
      exactMatch: false,
      sources: [
          layer: parcelLayer,
          searchFields: ["PartyName_1"],
          name: "Search by Owner",
          exactMatch: false,
          outFields: ["PartyName_1"],
          displayField: "PartyName_1",
          layer: parcelLayer,
          searchFields: ["PropertyAddress"],
          name: "Search by Address",
          exactMatch: false,
          outFields: ["PropertyAddress"],
          displayField: "PropertyAddress",
          layer: parcelLayer,
          searchFields: ["QuickRefID"],
          name: "Search by Quick Reference ID",
          exactMatch: false,
          outFields: ["QuickRefID"],
          displayField: "QuickRefID",
AMostafaH
If I did so, the same layer will appear many times in the suggestions list and I don't want that to happen.
I believe the best way is to use suggestionTemplate property and add all fields used in the searchFields property.
I will attach pictures for your scenario.
Thanks.
