How to develop a custom map with ArcGIS?
1047
05-10-2017 08:58 AM
chengchao
There are some objects are moving on the map.
The base picture of map is 'CAD Dwg' files.
I can know the latitude and longitude of the map with 'GPS'.
I can know the latitude and longitude of the objects which is moving on the map with 'GPS'.
It should not be developed on the GPS API.
I can only get the latitude and longitude by GPS with hardware devices.
There are some questions to ask:
1、Is there similar js framework to use?
2、Is there similar demo to reference?
3、Is there similar algorithm to achieve?
Thinking with myself.
4、Should the map must use canvas to achieve? Is there other way?
5、Is it necessary to convert dwg to a picture,for example png,jpg?
6、How to set the coordinate system of map is better?
7、How to draw the dots on the map?
8、How to connect the dots be a line?
I haven't done anything like this.
Please master to give directions and help me.
Thank you very much,master.
