In the Using FeatureTable sample, when the user clicks the close button on the FeatureTable's header, the table collapses but the ContentPane that contains the table does not resize, making it pointless for the user to close the table because they do not gain any extra space for the map.
I have a similar layout and need to know how to resize the content pane when the feature table is closed. I don't see any "table-close" event, so how do I resize the content pane when the user closes the table?
Solved! Go to Solution.
Jeff,
Here is a sample of how to do it:
<!DOCTYPE html> <html> <head> <meta http-equiv="Content-Type" content="text/html; charset=utf-8"> <title>Using FeatureTable</title> <link rel="stylesheet" href="http://js.arcgis.com/3.15/dijit/themes/claro/claro.css"> <link rel="stylesheet" href="http://js.arcgis.com/3.15/esri/css/esri.css"> <script src="http://js.arcgis.com/3.15/"></script> <style> html, body, #map{ width:100%; height:100%; margin:0; padding:0; } </style> <script> var map; require([ "esri/IdentityManager", "esri/layers/FeatureLayer", "esri/dijit/FeatureTable", "esri/geometry/webMercatorUtils", "esri/map", "dojo/dom-construct", "dojo/dom", "dojo/dom-style", "dojo/dom-class", "dojo/dom-geometry", "dojo/parser", "dojo/ready", "dojo/on", "dojo/_base/lang", "dijit/registry", "dijit/form/Button", "dijit/layout/ContentPane", "dijit/layout/BorderContainer", "dijit/form/TextBox" ], function ( IdentityManager, FeatureLayer, FeatureTable, webMercatorUtils, Map, domConstruct, dom, domStyle, domClass, domGeometry, parser, ready, on,lang, registry, Button, ContentPane, BorderContainer, TextBox ) { parser.parse(); ready(function(){ var myFeatureLayer; var map = new Map("map",{ basemap: "dark-gray" }); map.on("load", loadTable); var myButton = new Button({ label: "Load", onClick: loadTable }, "loadButton").startup(); function loadTable(){ // Create the feature layer myFeatureLayer = new FeatureLayer("https://services.arcgis.com/V6ZHFr6zdgNZuVG0/arcgis/rest/services/Warren_College_Trees/FeatureServer...", { mode: FeatureLayer.MODE_ONDEMAND, outFields: ["Collected","Crew","Status","Spp_Code","Cmn_Name","Sci_Name","Street","Native"], visible: true, id: "fLayer" }); on(myFeatureLayer, "load", function(evt){ console.log("Layer loaded"); var extent = myFeatureLayer.fullExtent; if (webMercatorUtils.canProject(extent, map)) { map.setExtent( webMercatorUtils.project(extent, map) ); } }); if(registry.byId("myTableNode")){ registry.byId("myTableNode").destroy(); domConstruct.create("div", {id: "myTableNode"}, dom.byId("bot")); console.log("re-creating table"); } // Add the feature layer to the map var oldLayer = map.getLayer("fLayer"); if(oldLayer){ map.removeLayer(oldLayer); } map.addLayer(myFeatureLayer); myTable = new FeatureTable({ "featureLayer" : myFeatureLayer, //"dateOptions": { // "timeEnabled" : true, // "timePattern" : "HH:mm:ss", // "datePattern" : "YYYY-MM-DD" //}, "hiddenFields": ["FID","C_Seq","Street"], // field that end-user can show, but is hidden on startup "map" : map }, 'myTableNode'); // load event (must be before startup) on(myTable, "load", function(evt){ console.log("The load event - ", evt); }); myTable.startup(); on(myTable, "dgrid-refresh-complete", function(evt){ console.log("The dgrid-refresh-complete event - ", evt); }); on(myTable, "dgrid-select", function(evt){ console.log("The dgrid-select event - ", evt); }); on(myTable, "dgrid-deselect", function(evt){ console.log("The dgrid-deselect event - ", evt); }); on(myTable.tableCloseButton, "click", function(evt){ if(domClass.contains(evt.target, "toggleClosed")){ console.info("Table is open"); domStyle.set(registry.byId("botCP").domNode, "height", "50%"); domStyle.set(registry.byId("mapCP").domNode, "height", "50%"); registry.byId('mainBC').resize(); }else{ console.info("Table is closed"); domStyle.set(registry.byId("botCP").domNode, "height", "10%"); domStyle.set(registry.byId("mapCP").domNode, "height", "90%"); registry.byId('mainBC').resize(); } }); } }); }); </script> </head> <body class="claro esri"> <div id="mainBC" data-dojo-type="dijit/layout/BorderContainer" data-dojo-props="design:'headline'" style="width:100%; height:100%;"> <div id="mapCP" data-dojo-type="dijit/layout/ContentPane" data-dojo-props="region:'center', splitter:true" style="height:50%"> <div id="map"></div> </div> <div id="botCP" data-dojo-type="dijit/layout/ContentPane" data-dojo-props="region:'bottom', splitter:true" style="height:50%"> <div id="myTableNode"></div> </div> </div> </body> </html>
Jeff,
I created a Plunk that demonstrates this.
Below is the code that changes the size of the pane when the FeatureTable's close button is clicked. It is modified from Robert Scheitlin, GISP's sample in the following ways.
// resize panel when table close is toggled.
table.tableCloseButton.addEventListener("click", function(e) {
var gridMenuNode = registry.byId(table._gridMenu).domNode;
var tableNode = registry.byId("tablePane").domNode;
var borderContainer = registry.byId("borderContainer");
var isOpening = e.target.classList.contains("toggleClosed");
if (isOpening) {
tableNode.style.height = tableNode.dataset.openHeight || "50%";
} else {
// Store the old height.
tableNode.dataset.openHeight = tableNode.style.height || [tableNode.clientHeight, "px"].join("");
// Set to "closed" height.
tableNode.style.height = [gridMenuNode.clientHeight, "px"].join("");
borderContainer.resize();
Jeff,
This is the second time I have seen you post about using native methods instead of dojo. I am curious to know why you think this is important. You are using the JS API with loads Dojo and Dojo has spend alot of time ensuring that their classes are supported across a large range of browsers (new and old) i.e. cross browser compatible. And not all the native methods you are using are supported by older browsers liek inline style. So what is your basis for not using Dojo-specific?
It’s mainly just personal preference. I am more familiar with the native DOM manipulation than I am with the Dojo equivalents. I then use polyfills to handle browsers that don’t support these methods.
Jeff,
OK, just seems like learning the dojo methods would be beneficial to you as you would not need to polyfill.
