How to change the Callout of a FeatureLayer that is already on the SceneView
1343
03-21-2024 02:34 AM
Yamakaze
I already have a FeatureLayer with Callout on SceneView, and I want to change the style of Callout, but it doesn't seem to be updated on SceneView.
This is my updated Callout style code: ↓
// get featureLayer.labelingInfo's cloned class
const labelingInfoCache = peaks.labelingInfo[0].clone()
// get featureLayer.labelingInfo.symbol cloned class
const symbol = labelingInfoCache.symbol.clone()
// disconnect from featurelayer
peaks.labelingInfo = null
// update properties
symbol.symbolLayers.at(0).material = {
  color: [Math.random() * 255, Math.random() * 255, Math.random() * 255],
symbol.callout = {
  type: "line",
  border: {
// Link to featurelayer to enable updates in sceneView
setTimeout(() => {
  labelingInfoCache.symbol = symbol
  peaks.labelingInfo = [labelingInfoCache]
 Every time I run these codes, I can see an update in the color of the Label text (by material.color), but the Callout for the Label is not updated.
How can I see updates on SceneView?
Yamakaze
If I set the featureLayer.elevationInfo.mode to 'on-the-ground', when I run the above code, I can see that the Callout on SceneView has been updated.
But I need to update Callout even if featureLayer.elevationInfo.mode is 'on-the-ground'
AndreasUlmer
Thanks for reporting, this seems to be a bug. Sent to dev team for further investigation.
I did a few tests but at the moment I can't provide a good workaround.
Use "on-the-ground" of course if that's an option.
Or clone/recreate the whole layer (with new callout config in constructor), but clearly not great either depending on your use case.
Will keep you posted if more intel comes up.
