How to Change RotateOrigin when using EditToolbar "esri/toolbars/edit"
2981
06-08-2016 10:16 PM
SumitZ
While using Editing tools | ArcGIS API for JavaScript​ is thier any way to rotate the polygon from specific rotateOrigin instead of centroid of the polygon.
We have the option to set the rotate origin when using geometryEngine.rotate() function [esri/geometry/geometryEngine | API Reference | ArcGIS API for JavaScript ] in same way i would like to rotate the polygon using EditToolbar but would like to rotate it around the different rotateorigin than the centroid of the polygon.
Sumit Zarkar
SumitZ
Robert Scheitlin, GISP​ any idea on this.
Thanks.
RobertScheitlin__GISP
Sumit Z,
  This this type of control exists in ArcMap there is nothing in the JS API to allow this type of control.
