How to calculate geodesic area of polygons on map
7840
16
03-16-2020 06:11 AM
rsharma
Hi i want to calculate area of polygons drawn on map geometry, any arcgis sample will be helpful
RobertScheitlin__GISP
Rajni,
  A ring is just an array of coordinate and not an actual geometry class thus the geodesicArea method is failing.
Here is what you need to do instead.
      function calculateArea() {
        var area = 0;
        graphicsLayer.graphics.map(function (grap) {
          area = geometryEngine.geodesicArea(grap.geometry, "hectares");
        console.log(area);
      } //End calculateArea‍‍‍‍‍‍‍
BenElan
Esri Alum
Take a look at the measure widget: Measurement in 2D | ArcGIS API for JavaScript 4.14
Noah-Sager
There is also a lot of good information inside the GeometryEngine class:
geometryEngine | ArcGIS API for JavaScript 4.14
rsharma
Hi Noah , I m trying to get geometry of all polygons from a map with below code, but doen't get rings area in console.
function calculateArea(){
         graphicsLayer.graphics.map(function(grap){
          var updatedGeometry = webMercatorUtils.webMercatorToGeographic(grap.geometry);
          var rings_for_area = updatedGeometry.rings;
          console.log(rings_for_area);//return all rings
     var area = geometryEngine.geodesicArea(rings_for_area, "hectares");
        console.log(area);//doesn't return area
KenBuja
MVP Esteemed Contributor
You have a scope problem. Since the variable rings_for_area is declared inside the map function, it's not available outside the function. Why aren't you calculating the area of the rings inside the map function and summing that up?
rsharma
Hi ken, this time i summed it up but due to this bolded code to calculate area, my whole map stops working. No error in console even. No area consoled even.
          var rings_for_area=[];
          var k=0;
          var rings_area = updatedGeometry.rings;
                  rings_for_area= [];
                  rings_area.forEach(function(ring, i) {
                    rings_for_area=ring;
                     k++;
        console.log(area);
       }//End calculateArea
rsharma
Do i need to convert them rings_for_area to  webMercatorUtils.geographicToWebMercator, Ok i have converted it and now it returns 0 area value, even when i have a polygon on map
          var k=0;
                  rings_for_area= [];
                     k++;
        var area = geometryEngine.geodesicArea( webMercatorUtils.geographicToWebMercator(rings_for_area), "hectares");
        console.log(area);
KenBuja
Since the geodesicArea method looks like it only takes a single polygon, try calculating that for each ring in your forEach loop
  var area = 0;
      area += geometryEngine.geodesicArea( webMercatorUtils.geographicToWebMercator(ring), "hectares");
  console.log(area);
}//End calculateArea‍‍‍‍‍‍‍‍‍‍‍
rsharma
Hi ken , i used your code as it is, and it still returns 0. i called it here , do i need to call it somewhere else
function addGraphics(vertices) {
          //const vertices = <?php echo json_encode($map_ring_coordinate);?>;
          const polygon = createGeometry(vertices);
          validSymbol = createSymbol([255, 255, 255, 0.3], "solid", 2, [
            255, 121,5]);
          newDevelopmentGraphic = new Graphic({
            geometry: webMercatorUtils.geographicToWebMercator(polygon),
            symbol: validSymbol,
            attributes: {
              newDevelopment: "new store"
          graphicsLayer.addMany([newDevelopmentGraphic]);
         calculateArea();
      } //End addGraphics
Rajni,
        var area = 0;
        console.log(area);
