I did not find an easy way to calculate the distance (from the origine) of a point on a polyline using web app builder (API Javascript 3.25)
I have a polyline with 10 points and a point which is over the polyline.
I do not want to use a SOE or any server solution to find the distance from the start of the polyline to this point.
I found only one way to do it : (pseudo code) :
let distance = 0;
let numberOfPoints = myPolyline.paths[0].length;
for (let i = 0 ; i < numberOfPoints - 1 ; i += 1){
let myPath = [myPolyline.paths[0], myPolyline.paths[0][i+1]]
if (this.isMyPointOnMyPath(myPath, myPoint)){
distance += this.distanceBetweenTwoPoints(myPolyline.paths[0], myPoint);
return distance;
else {
distance += myPath.length;
return 0.0;
I think this solution a little bit complex (especially the function isMyPointOnMyPath where I need to use cross product vector).
Is there an easier way to get the distance using 3.xyz javascript API ?
I want to find the distance because I need to get a M value of my point on the polyline (I think it's not possible using web app Builder and 3.xyz javascript api).
With my polyline I have two attributes (start M, End M) and it should be easy to get M value of my point.
best regards,
Sylvain.
