how to arcgis javascript vertex undoManager
2682
06-01-2016 02:11 AM
ParkSeungHyun
I try to undo / redo the edit vertex using undomanager.
Graphic objects are tested. But I do not know what to do Edit vertex  undo / redo.
Is it possible the vertex undo / redo?
I looked to find many examples have not found the answer.
i`m korean beginner programmer. help me~ T.T
       function initEditing(evt) {
          console.log("initEditing", evt);
          var currentLayer = null;
          var layers = arrayUtils.map(evt.layers, function(result) {
            return result.layer;
            console.log("result ==== "+result);
          console.log("layers", layers);
           editToolbar = new Edit(map);
          editToolbar.on("deactivate", function(evt) {
         console.log("deactivate !!!! ");
            currentLayer.applyEdits(null, [evt.graphic], null);
          arrayUtils.forEach(layers, function(layer) {
            var editingEnabled = false;
            layer.on("dbl-click", function(evt) {
              event.stop(evt);
              if (editingEnabled === false) {
                editingEnabled = true;
                editToolbar.activate(Edit.EDIT_VERTICES , evt.graphic);
                pre_evt = evt.graphic;
                editToolbar.on("vertex-move-stop", function(evt){
                console.log("vertex-move-stop~");
                g_evt = evt;
                console.log("evt.transform ===== " +evt.transform);
              var operation = new esri.dijit.editing.Update({
              featureLayer : landusePointLayer,
              preUpdatedGraphics:pre_evt,
                         postUpdatedGraphics: evt.graphic
                  var operation = new CustomOperation.Add({
                                  graphicsLayer: pre_evt._graphicsLayer,
                                    addedGraphic: evt.graphic
                                undoManager.add(operation);
              console.log("operation ======== ",operation);
                console.log("dbl-click  & eidt  true");
              } else {
                currentLayer = this;
                editToolbar.deactivate();
                console.log("dbl-click  & eidt false ");
thejuskambi
Robert Scheitlin, GISP​ could you please moved this to Javascript forum.
thejuskambi
