How to add Widgets in excisting code.
6209
19
12-03-2018 08:25 PM
irtizahussain
I have a code where drop down is use to show different state and countries, in which i use Map image layer for layer of version 4.9. The problem is i want to add different widgets on my project such as search widget and other widgets but i have not succeed.
My code,
<!DOCTYPE html>
<html>
<head>
  <meta http-equiv="Content-Type" content="text/html; charset=utf-8">
  <meta name="viewport" content="initial-scale=1, maximum-scale=1,user-scalable=no" />
  <title>Drop Down Test</title>
  <link rel="stylesheet" href="http://js.arcgis.com/4.9/dijit/themes/claro/claro.css">
  <link rel="stylesheet" href="https://js.arcgis.com/4.9/esri/css/main.css">
  <script src="https://js.arcgis.com/4.9/"></script>
  <style>
    html,
    body,
    #mainWindow {
      height: 100%;
      width: 100%;
      margin: 0;
      padding: 0;
    body {
      background-color: #FFF;
      overflow: hidden;
      font-family: "Trebuchet MS";
    #header {
      height: 3%;
      overflow: auto;
  </style>
  <script>
    var map;
    require([
      "esri/Map",
      "esri/views/MapView",
      "dojo/on",
      "esri/tasks/support/Query",
      "esri/layers/FeatureLayer",
      "dojo/store/Memory",
      "dojo/_base/array",
      "dojo/_base/lang",
      "esri/request",
      "dojo/parser",
      "dijit/registry",
      "dijit/layout/BorderContainer",
      "dijit/layout/ContentPane",
      "dijit/form/Button",
      "dijit/form/ComboBox",
      "dojo/domReady!"
    ], function(
      Map, MapView, on, Query, FeatureLayer, Memory, array, lang, esriRequest, parser, registry
      parser.parse();
      map = new Map({
        basemap: "topo"
      var view = new MapView({
        container: "map",
        map: map,
        center: [-98.1883, 37.0868],
        zoom: 5
      esriRequest('http://sampleserver6.arcgisonline.com/arcgis/rest/services/Census/MapServer/3/query?where=1%3D1&outF...',
        responseType:'json',
        timeout:15000
      }).then(lang.hitch(this,function(response){
        var store2 = new Memory({data:[]});
        registry.byId("stateSelect").set('store',store2);
        var data = array.map(response.data.features,lang.hitch(this,function(feat, index){
          var name = feat.attributes.STATE_NAME;
          var value = feat.attributes.STATE_NAME;
          var dataItem = {
            value:value
          return dataItem;
        store2 = new Memory({data:data});
      var States = new FeatureLayer({
        url: "http://sampleserver6.arcgisonline.com/arcgis/rest/services/Census/MapServer/3",
        outFields: ["*"]
      var Counties = new FeatureLayer({
        url: "http://sampleserver6.arcgisonline.com/arcgis/rest/services/Census/MapServer/2",
        outFields: ["*"]
      //map.addMany([States,Counties]);
      app = {
        zoomRow: function(id, which){
          var sym = {
            type: "simple-fill",  // autocasts as new SimpleFillSymbol()
            color: [255, 0, 0, 0.5],
            outline: {  // autocasts as new SimpleLineSymbol()
              color: [128, 128, 128, 1],
              width: "0.5px"
          }, gra;
          view.graphics.removeAll();
          var query = States.createQuery();
          var thePoly, theExtent;
          if(which == "State"){
            query.outFields=[];
            query.outSpatialReference = view.spatialReference;
            query.where = "STATE_NAME='" + (id).toString() + "'";
            console.info(query.where);
            query.returnGeometry = true;
            States.queryFeatures(query).then(function(response){
              gra = response.features[0];
              gra.symbol = sym;
              view.graphics.add(gra);
              thePoly = gra.geometry;
              theExtent = thePoly.extent.expand(2); //Zoom out slightly from the polygon's extent
              view.goTo(theExtent);
            esriRequest("http://sampleserver6.arcgisonline.com/arcgis/rest/services/Census/MapServer/2/query?where=STATE_NAME...'" + id.toString() + "'&outFields=NAME&returnGeometry=false&orderByFields=NAME&returnDistinctValues=true&f=json",
              responseType: "json",
              timeout:15000
              registry.byId("countySelect").set('store',store2);
                var name = feat.attributes.NAME;
                var dataItem = {
                return dataItem;
              document.getElementById('countySelect').value = "Select County";
          }else if(which == "County"){
            query = Counties.createQuery();
            var county = (id).toString();
            county = county.replace(" County", "");
            query.where = "NAME='" + county + "'";
            query.outFields=[];
            Counties.queryFeatures(query).then(function(response){
              gra.symbol = sym;
  </script>
</head>
<body class="claro">
  <div id="mainWindow" data-dojo-type="dijit/layout/BorderContainer" data-dojo-props="design:'headline', gutters:false" style="padding:0px;margin:0px;">
    <div id="header" data-dojo-type="dijit/layout/ContentPane" data-dojo-props="region:'top'" style="overflow:hidden;border:none;border-bottom: 3px solid #CC9900;font-family: Windows;font-size:14pt; color: #FFFFFF;background: #000000; "> Select a State/County and zoom to it on the map:
      <input id="stateSelect" data-dojo-type="dijit/form/ComboBox" value="Select State" onchange="app.zoomRow(document.getElementById('stateSelect').value, 'State');" data-dojo-props="maxHeight: 200" />
      <input id="countySelect" data-dojo-type="dijit/form/ComboBox" value="Select County" onchange="app.zoomRow(document.getElementById('countySelect').value, 'County');" />
      <input type="hidden" name="stateabbr" id="stateabbr" />
    </div>
    <div id="map" data-dojo-type="dijit/layout/ContentPane" data-dojo-props="region:'left'" style="width:100%;height:95%;border:none;padding:0px;margin:0px;"></div>
  </div>
</body>
</html>
Tags (1)
RobertScheitlin__GISP
Irtiza,
Here is that code with the Search widget added:
<!DOCTYPE html>
<html>
<head>
  <style>
    html,
    body,
    #mainWindow {
      height: 100%;
      width: 100%;
      margin: 0;
      padding: 0;
    body {
    #header {
      height: 32px;
      overflow:visible;
      font-size:14pt;
      color: #FFFFFF;
      z-index: 99;
      line-height: 32px;
    .searchDiv {
      float: right;
      z-index: 99;
    #viewDiv {
      width: 100%;
      height: calc(100% - 32px);
      border: none;padding:0px;
      margin: 0px;
  </style>
  <script>
    var map;
    require([
      "esri/Map",
      "dojo/on",
      "dojo/_base/array",
      "dojo/_base/lang",
      "esri/request",
      "dojo/parser",
      "dijit/registry",
      "esri/widgets/Search",
      "dojo/domReady!"
    ], function(
      Map, MapView, on, Query, FeatureLayer, Memory, array, lang, esriRequest, parser, registry, Search
      parser.parse();
      map = new Map({
        basemap: "topo"
        container: "viewDiv",
        map: map,
        zoom: 5
      var searchWidget = new Search({
        view: view,
        container: "searchDiv"
        timeout:15000
          var dataItem = {
            value:value
          return dataItem;
        outFields: ["*"]
        outFields: ["*"]
      app = {
          var sym = {
              width: "0.5px"
          }, gra;
            query.outFields=[];
              gra.symbol = sym;
              timeout:15000
                var dataItem = {
                return dataItem;
            query.outFields=[];
              gra.symbol = sym;
  </script>
</head>
  <div id="mainWindow" data-dojo-type="dijit/layout/BorderContainer" data-dojo-props="design:'headline', gutters:false">
    <div id="header" data-dojo-type="dijit/layout/ContentPane" data-dojo-props="region:'top'"> Select a State/County and zoom to it on the map:
      <input id="countySelect" data-dojo-type="dijit/form/ComboBox" value="Select County" onchange="app.zoomRow(document.getElementById('countySelect').value, 'County');"  data-dojo-props="maxHeight: 200" />
      <div id="searchDiv" class='searchDiv'></div>
    </div>
    <div id="viewDiv" data-dojo-type="dijit/layout/ContentPane" data-dojo-props="region:'left'"></div>
  </div>
</body>
</html>
Irtiza,
<!DOCTYPE html>
<html>
<head>
  <style>
    html,
    body,
    #mainWindow {
      height: 100%;
      width: 100%;
      margin: 0;
      padding: 0;
    body {
    #header {
      height: 32px;
      overflow:visible;
      font-size:14pt;
      color: #FFFFFF;
      z-index: 99;
      line-height: 32px;
    .searchDiv {
      float: right;
      z-index: 99;
    #viewDiv {
      width: 100%;
      margin: 0px;
  </style>
  <script>
    var map;
    require([
      "esri/Map",
      "dojo/on",
      "dojo/_base/array",
      "dojo/_base/lang",
      "esri/request",
      "dojo/parser",
      "dijit/registry",
      "dojo/domReady!"
    ], function(
      parser.parse();
      map = new Map({
        basemap: "topo"
        map: map,
        zoom: 5
        view: view,
        timeout:15000
          var dataItem = {
            value:value
          return dataItem;
        outFields: ["*"]
        outFields: ["*"]
      app = {
          var sym = {
              width: "0.5px"
          }, gra;
            query.outFields=[];
              gra.symbol = sym;
              timeout:15000
                var dataItem = {
                return dataItem;
            query.outFields=[];
              gra.symbol = sym;
  </script>
</head>
    </div>
  </div>
</body>
</html>
irtizahussain
thanks for the help Robert Scheitlin, GISP‌ can i add more widgets on this like home widget etc on this project?
Yes
irtizahussain
but i tried different widgets they are not working properly like home, legend and layer list widget!! they just appeared on screen in incorrect format.
Show me the code changes you tried.
irtizahussain
The code is below , in this code when i try to add widgets the home widget code is treated as search widget and search widget code is treated as home widget code. Why this is happening?? what's the reason behind??
After this i want to add more widgets like Base map Gallery  widget , layer list widget,Direct Line Measurement3D and  Area Measurement 3D widget, but unfortunately i am fail to do this.
<!DOCTYPE html>
<html>
<head>
<style>
html,
body,
#mainWindow {
height: 100%;
width: 100%;
margin: 0;
padding: 0;
body {
#header {
height: 32px;
overflow:visible;
font-size:14pt;
color: #FFFFFF;
z-index: 99;
line-height: 32px;
.searchDiv {
float: right;
z-index: 99;
.homeDiv{
float: right;
z-index:99;
.galleryDiv{
float: left;
z-index:99;
#viewDiv {
width: 100%;
margin: 0px;
</style>
<script>
var map;
require([
"esri/Map",
"dojo/on",
"dojo/_base/array",
"dojo/_base/lang",
"esri/request",
"dojo/parser",
"dijit/registry",
"esri/widgets/Home",
"esri/widgets/LayerList",
"esri/widgets/BasemapGallery",
"dojo/domReady!"
], function(
Map, MapView, on, Query, FeatureLayer, Memory, array, lang, esriRequest, parser, registry, Search, Home, LayerList, BasemapGallery
parser.parse();
map = new Map({
basemap: "topo"
map: map,
zoom: 5
view: view,
view.ui.add(searchDiv,"top-left");
var homeWidget = new Home({
view: view,
container: "homeDiv"
var layer = new LayerList({
view: view,
container: "galleryDiv"
view.ui.add(layer,"top-right");
var search1 = new Home({
view : view,
container: "search1Div"
view.ui.add(search1,"top-right");
timeout:15000
var dataItem = {
value:value
return dataItem;
outFields: ["*"]
outFields: ["*"]
app = {
var sym = {
width: "0.5px"
}, gra;
query.outFields=[];
gra.symbol = sym;
timeout:15000
var dataItem = {
return dataItem;
query.outFields=[];
gra.symbol = sym;
</script>
</head>
<div id="homeDiv" class='homeDiv'></div>
<div id="galleryDiv" class='galleryDiv'></div>
<div id="search1Div" class='search1Div'></div>
</div>
</div>
</body>
</html>
Irtiza,
  OK you are missing a very basic concept of AMD JavaScript programming.
You have:
require([
"esri/Map",
"dojo/on",
"dojo/_base/array",
"dojo/_base/lang",
"esri/request",
"dojo/parser",
"dijit/registry",
"dojo/domReady!"
], function(
AMD style programming requires the require array list and the subsequent vars to be in the same order.
require([
"esri/request",
"dojo/parser",
"dijit/registry",
], function(
Map, MapView, on, Query, FeatureLayer, Memory, array, lang, esriRequest, parser, registry, Home, Search, LayerList, BasemapGallery
Notice that the above require array has registry, Home, Search, LayerList, BasemapGallery and the functions vars has then listed in the same order.
irtizahussain
yeah that's the exact thing i was looking for, thanks
irtizahussain
there is another issue, when i select any state from drop down then it focus on that particular area, can you tell me how can i remove that focus after i search the state!?
