How to add text to the map as a graphic?
1591
02-22-2013 02:04 AM
StephenLead
Honored Contributor
The draw toolbar allows the user to create points, lines and polygons, which can be added to the map as graphic objects.
Is there a similar mechanism to create free text? This would be similar to the Draw toolbar in ArcMap, which has an option to add labels.
Steve
RahulMetangale1
Steve,
You can use TextSymbol for this purpose. Here is the API reference link:
http://help.arcgis.com/en/webapi/javascript/arcgis/jsapi/#textsymbol
-Rahul
RahulMetangale1
Steve,
-Rahul
StephenLead
Honored Contributor
Hi Rahul,
So you could attach a listener to the draw toolbar, and pop up a text-input object to ask for the text input, then symbolise it with a textSymbol. Cool.
Thanks for the tip,
Steve
RahulMetangale1
Steve,
You can add a tool for text label in draw toolbar. Add the necessary graphic layer when it is clicked. Then start listening for map click event. On map click event you can show a info window where user can enter label information, set the font etc.
I hope this helps.
Rahul
