How to add line symbol with single-sided outline?
2511
05-16-2022 11:11 AM
mmqn
Is there a way to render a line symbol that has an outline on only one side?
I know a workaround for a line with an outline on both sides could be achieved by rendering two overlapping lines with one below the other at a greater width, but a one-sided outline seems trickier.
This is a feature that is supported by other ArcGIS products, but it doesn't seem there's a way to do it for the JS API. Attached screenshot is how it should look, taken from ArcGIS Enterprise.
Tags (1)
AnneFitz
AnneFitz
mmqn
This is great; thank you so much!
For posterity, the solution was to add a second line in the same layer with a CIMGeometricEffectOffset effect.
