How to Access Secured ArcGIS Server Map Service?
4129
04-01-2021 01:17 AM
ZohaibUddinKhan
Hello Everyone,
Thanks for reading my post.
We're using JS API to access the secured service and we're expecting it wouldn't ask for the user credentials as we're passing Token, but it's not working as expected and asking for credentials.
Following is the code:-
<!DOCTYPE html>
<html>
<head>
    <meta charset="utf-8" />
    <meta name="viewport" content="initial-scale=1, maximum-scale=1, user-scalable=no" />
    <title></title>
    <style>
        html,
        body,
        #viewDiv {
            padding: 0;
            margin: 0;
            height: 100%;
            width: 100%;
    </style>
    <link rel="stylesheet" href="https://js.arcgis.com/4.18/esri/themes/light/main.css">
    <script src="https://js.arcgis.com/4.18/"></script>
    <script>
        require(["esri/config", "esri/Map", "esri/views/MapView", "esri/layers/FeatureLayer"], function (esriConfig, Map, MapView, FeatureLayer) {
            esriConfig.apiKey = "AAPK9c1060b46848481f85233a3e7-Bf1Yng_hEZz";
            const map = new Map({
                basemap: "arcgis-topographic" // Basemap layer service
            const view = new MapView({
                map: map,
                center: [115.860299, -31.954594], // Longitude, latitude
                zoom: 13, // Zoom level
                container: "viewDiv" // Div element
            const featureLayerUrl = "https://services.slip.wa.gov.au/arcgis/rest/services/Landgate_v2_Subscription_Services/Cadastral/MapServer/41";
            //const featureLayerUrl = "https://token.slip.wa.gov.au/arcgis/rest/services/Landgate_v2_Subscription_Services/Cadastral/MapServer/41";
            var layer = new FeatureLayer({
                url: featureLayerUrl,
                customParameters: {
                    "token": "nXKRnEHxOLrfCyV_209zi9ht45yzP-IIrvjZzsrI."//Get the token from https://token.slip.wa.gov.au/arcgis/tokens/
            map.add(layer);
    </script>
</head>
<body>
    <div id="viewDiv"></div>
</body>
</html>
BlakeTerhune
You cannot reuse the same token like that. You have to generate a token when the app loads and gets user credentials. You could also consider application authentication if you don't want to get credentials from each user.
ZohaibUddinKhan
Thanks @BlakeTerhune for the reply.
  1. Is there any other way apart from  application authentication if I don't want to get credentials from each users?
  2. I changed my code and now generating the Token in the code like below and CORS is the challenge I'm facing now. Any suggestion?:-
<script>
        function getToken() {
            var settings = {
                "url": "https://token.slip.wa.gov.au/arcgis/tokens/generateToken",
                "method": "POST",
                "timeout": 0,
                "headers": {
                    "Content-Type": "application/x-www-form-urlencoded"
                "data": {
                    "username": "[email protected]",
                    "password": "678965",
                    "client": "referer",
                    "ip": "",
                    "referer": "https://www.domain.com/",
                    "expiration": "60",
                    "f": "json"
                async: false
            return $.ajax(settings).done().responseText;
        console.log('1');
        var result = getToken();
        var token1 = $.parseJSON(result).token;
            esriConfig.apiKey = "AAPK9c1060b46848481f85233a3e-_hEZz";
                map: map,
                customParameters: {
                    "token": token1
            map.add(layer);
    </script>
This is the Cors challenge:-
Thanks for your time.
BlakeTerhune
CORS is always a challenge. Have a look at the documentation to see if you can identify the solution for your particular setup. The easiest (but not always most reasonable) solution is to run your app from the same server as your services.
MarkEastwood
Any luck getting this to work?
RiddhiM
has anyone found a solution to this issue?
