How do you set the Directions widget to default to "All" sources searchOptions?
3561
01-14-2016 11:53 PM
lasinh
default  , the first sources in the list  is selected. how to select all sources in my code:
<!DOCTYPE html>
<html>
  <head>
    <meta http-equiv="Content-Type" content="text/html; charset=utf-8">
    <meta name="viewport" content="initial-scale=1, maximum-scale=1,user-scalable=no">
    <title>Directions Widget</title>
    <link rel="stylesheet" href="http://js.arcgis.com/3.14/dijit/themes/claro/claro.css">
    <link rel="stylesheet" href="http://js.arcgis.com/3.14/esri/css/esri.css">
    <style>
      html, body, #map {
        height:100%;
        width:100%;
        margin:0;
        padding:0;
      body {
        background-color:#FFF;
        overflow:hidden;
        font-family:"Trebuchet MS";
    </style>
    <script src="http://js.arcgis.com/3.14/"></script>
    <script>
        require([
       "esri/map", "esri/tasks/locator", "esri/InfoTemplate", "esri/geometry/webMercatorUtils", "esri/dijit/Directions", "esri/dijit/Search", "esri/layers/FeatureLayer",
        "dojo/parser",
        "dijit/layout/BorderContainer", "dijit/layout/ContentPane", "dojo/domReady!"
      ], function (
         Map, Locator, InfoTemplate, webMercatorUtils, Directions, Search, FeatureLayer,
        parser
          parser.parse();
          //all requests to route.arcgis.com will proxy to the proxyUrl defined in this object.
          esriConfig.defaults.io.proxyUrl = "/proxy/";
          var map = new Map("map", {
              basemap: "gray",
              center: [-97, 38], // lon, lat
              zoom: 5
          directionTimDuong = new Directions({
              map: map,
              autoSolve: false,
              dragging: false,
              showClearButton: true,
              maxStops: 5,
              showReverseStopsButton: true,
              //  showTravelModesOption: true,
              mapClickActive: true,
              routeTaskUrl: "http://sampleserver3.arcgisonline.com/ArcGIS/rest/services/Network/USA/NAServer/Route",
              searchOptions: {
                  sources: [
                            featureLayer: new FeatureLayer("http://services.arcgis.com/V6ZHFr6zdgNZuVG0/arcgis/rest/services/CongressionalDistricts/FeatureServe..."),
                            searchFields: ["DISTRICTID"],
                            displayField: "DISTRICTID",
                            exactMatch: false,
                            outFields: ["DISTRICTID", "NAME", "PARTY"],
                            name: "Congressional Districts",
                            placeholder: "3708",
                            maxResults: 6,
                            maxSuggestions: 6,
                            //Create an InfoTemplate and include three fields
                            infoTemplate: new InfoTemplate("Congressional District", "District ID: ${DISTRICTID}</br>Name: ${NAME}</br>Party Affiliation: ${PARTY}"),
                            enableSuggestions: true,
                            minCharacters: 0
                                featureLayer: new FeatureLayer("http://services.arcgis.com/V6ZHFr6zdgNZuVG0/arcgis/rest/services/US_Senators/FeatureServer/0"),
                                searchFields: ["Name"],
                                displayField: "Name",
                                exactMatch: false,
                                outFields: ["*"],
                                placeholder: "Senator name",
                                maxResults: 6,
                                maxSuggestions: 6,
                                infoTemplate: new InfoTemplate("Senator information", "Name: ${Name}</br>State: ${State}</br>Party Affiliation: ${Party}</br>Phone No: ${Phone_Number}<br><a href=${Web_Page} target=_blank ;'>Website</a>"),
                                minCharacters: 0
          }, "dir");
          directionTimDuong.startup();
    </script>
  </head>
  <body class="claro">
    <div data-dojo-type="dijit/layout/BorderContainer"
         data-dojo-props="design:'headline', gutters:false"
         style="width:100%;height:100%;">
      <div data-dojo-type="dijit/layout/ContentPane"
           data-dojo-props="region:'right'"
           style="width:250px;">
        <div id="dir"></div>
      </div>
      <div id="map"
           data-dojo-props="region:'center'">
      </div>
    </div>
  </body>
</html>
AmritKumar1
Use the code mentioned in the following link:
https://github.com/amritkumar90/Directions-widget-with-searchOptions/blob/master/
Make necessary modifications as required. Hope this helps!
--Amrit
