How do I write address candidates to a grid?
4406
07-30-2015 12:10 PM
ChrisSergent
I want to place my address candidates in a grid that is created on the fly. I want to then allow the user to be able to click on one of the address candidates in the list and display that in the address candidate that was clicked in the console.
I've looked here and this looks like what I want, but it also looks like too much. I am not sure what I could take out: Show find task results in a DataGrid | ArcGIS API for JavaScript
I have also looked here:  dojox.grid.DataGrid — The Dojo Toolkit - Reference Guide
My code will not run correctly in JSBin. I have done my testing in Google Chrome.
Here is my code:
<!DOCTYPE html>
<html lang="en">
<head>
    <meta charset="utf-8">
    <meta http-equiv="X-UA-Compatible" content="IE=edge">
    <meta name="viewport" content="width=device-width, initial-scale=1.0">
    <link rel="stylesheet" href="http://js.arcgis.com/3.14/dijit/themes/claro/claro.css">
    <link rel="stylesheet" href="http://js.arcgis.com/3.14/esri/css/esri.css">
    <title></title>
    <!-- HTML5 shim and Respond.js IE8 support of HTML5 elements and media queries -->
    <!--[if lt IE 9]>
       <script src="//cdnjs.cloudflare.com/ajax/libs/html5shiv/3.7/html5shiv.min.js"></script>
       <script src="//cdnjs.cloudflare.com/ajax/libs/respond.js/1.4.2/respond.min.js"></script>
    <![endif]-->
</head>
<body>
    <label id="lblOwnerAddress" for="ownerAddress">Owner's Address</label>
    <input type="text" id="ownerAddress" name="ownerAddress" value="111 S Main" />
    <script src="http://js.arcgis.com/3.14/"></script>
    <script>
        require([
                 'dojo/on',
                 'esri/tasks/locator'
         function (on, Locator) {
             on(document.getElementById('ownerAddress'), 'focusout', checkAddress);
             function checkAddress() {
                 var locator = new Locator("http://maps.decaturil.gov/arcgis/rest/services/Public/WebAddressLocator/GeocodeServer");
                 //console.log(document.getElementById('ownerAddress').value);
                 var node = document.getElementById('ownerAddress');
                 // according to your service it takes Single Line
                 var params = {
                     "Single Line Input": node.value
                 locator.addressToLocations(params).then(function (addressCandidates) {
                     //console.log('success', addressCandidates);
                     //console.log(addressCandidates.length);
                     if (addressCandidates.length > 1) {
                         for (a = 0; a < addressCandidates.length; a++) {
                             // This is the address that should go into a grid cell
                             console.log(addressCandidates.address);
                     var adresses = addressCandidates.map(function  {
                         return x.address;
                     //console.log(adresses);
                 }).otherwise(function (err) {
                     console.log('somethings wrong', err);
    </script>
</body>
</html>
ChrisSmith7
Honored Contributor
Chris,
Will something like this work for you?
GRID test - JSFiddle
I used the dojo grid (dojox.grid.DataGrid — The Dojo Toolkit - Reference Guide)... when the control loses focus, the grid will render and then populate, which I think is what you were going for:
Pre:
Focus lost:
New address query:
ChrisSmith7
Honored Contributor
Chris,
Pre:
Focus lost:
New address query:
ChrisSergent
That works well. Thank you. Any idea how to get a grid to display in a bootstrap dialog box in my other question: https://community.esri.com/message/540491?et=watches.email.thread#540491
ChrisSmith7
Honored Contributor
Chris - I replied in your other thread with some ideas.
