How do I Refresh Map/GrphicLayer after Remove element
5356
7
07-03-2016 01:07 AM
DrorElgabsi
I am using the 4.0 API,
trying to remove elements from the graphic layer some times leave the icon on the map...
how do I refresh it?
all the old examples that I sow saying do dataLayer.refresh(); or setExtent...
needless to say it didn't work!
Tags (1)
SteveCole
Honored Contributor
I wonder if you have to use watch as explained in this thread. It's not exactly what you're trying to do but it is responding after a given event so it might still be applicable.
DrorElgabsi
Didn't help... no reload/refresh there
FC_Basson
I would think it refreshes automatically after something like:
graphicsLayer.remove(graphicsLayer.graphics.items)
DrorElgabsi
it doesn't...
or maybe i'm doing something worng...
            view.popup.on("trigger-action", function (evt) {
                if (evt.action.id === "closeEvent") {
                    eventsLayer.remove(view.popup.selectedFeature);
                    view.popup.visible = false;
                else if (evt.action.id === "closeAllEvents") {
                    eventsLayer.removeAll();
FC_Basson
If the graphic is not in the eventsLayer, then the remove function won't work.
You can try:
view.graphics.remove(view.popup.selectedFeature);
or
view.graphics.removeAll();
If you provide more code someone might be able to help.
DrorElgabsi
tried using view.graphics.remove(view.popup.selectedFeature);  -> didn't work
my code is pretty straight forward...
create the GraphicLayer and add it to the map:
        var dataLayer = new GraphicsLayer({
     map.add(eventsLayer);
I'm adding graphics to the eventsLayer like that (using SignalR messaging):
function AddEvent(message,position)
            var x = JSON.parse(position);
            var data = JSON.parse(message);
            ElementAtt = {
                Source: data.Source,
                Triggers: data.Trigger,
                Time: new Date().toLocaleString(),
                Description: data.IdDescription,
                Latitude: x.X,
                Longitude: x.Y
            point = new Point({
                longitude: x.Y,
                latitude:  x.X
            pointGraphic = new Graphic({
                geometry: point,
                symbol: eventMarkerSymbol,
                attributes: ElementAtt,
                popupTemplate: eventTemplate
            eventsLayer.add(pointGraphic);
            view.goTo(Point);
the problematic part....
removing elements(Using popup action):
DrorElgabsi
for future reference the problem was that I used the Graphic id with my own id.
so removing it did not work
