How do I get my layer checkboxes to update layer visibility?
11678
22
05-01-2015 11:37 AM
ChrisSergent
I am trying to use this sample to toggle layers: Toggle layer visibility | ArcGIS API for JavaScript  but I receive this error message:
TypeError: Cannot read property 'on' of null {stack: (...), message: "Cannot read property 'on' of null"}
  1. message: "Cannot read property 'on' of null"
  2. stack: (...)
  3. get stack: function () { [native code] }
  4. set stack: function () { [native code] }
  5. __proto__: Error
"in domReady callback"
"TypeError: Cannot read property 'on' of null
and here is my code:
var visibleLayerIds = [];
    on(dom.byId("lyrSigns"), "change", updateLayerVisibility);
    on(dom.byId("lyrSupports"), "change", updateLayerVisibility);
    function updateLayerVisibility() {
        var inputs = query(".list_item");
        var inputCount = inputs.length;
        for (var i = 0; i < inputCount; i++) {
            if (inputs.checked) {
                visibleLayerIds.push(inputs.value);
        if (visibleLayerIds.length === 0) {
            visibleLayerIds.push(-1);
        layer.setVisibleLayers(visibleLayerIds);
And here is my project on github: csergent45/streetSigns · GitHub
ChrisSergent
I appreciate everyone's help. Thanks to everyone for your help. I clicked like and helpful to give you all points. Here is the final code that I came up with:
on(dom.byId("lyrSigns"), "change", updateSignLayerVisibility);
    on(dom.byId("lyrSupports"), "change", updateSupportLayerVisibility);
    function updateSignLayerVisibility() {
        if (document.getElementById('lyrSigns').checked) {
            app.signLayer.setVisibility(true);
        } else {
            app.signLayer.setVisibility(false);
    function updateSupportLayerVisibility() {
        if (document.getElementById('lyrSupports').checked) {
            app.supportLayer.setVisibility(true);
        } else {
            app.supportLayer.setVisibility(false);
I was hoping for a single loop, but this works.
RobertScheitlin__GISP
Chris,
  Seems like you could lessen your code a little by doing this:
        } else {
        } else {
ChrisSergent
Awesome! That worked nicely.
Chris,
  Even better:
        app.signLayer.setVisibility(document.getElementById('lyrSigns').checked);
        app.supportLayer.setVisibility(document.getElementById('lyrSupports').checked);
ChrisSergent
Very nice. So this is setting visibility based on the value of checked. Is that correct?
Correct
LianaSmith
Hi Robert,
I tried using your code but I get an error that "0x800a1391 - JavaScript runtime error: 'on' is undefined" However i defined "on" in my default file like this " dojo.require("dojo/on");"
Should I declare it differently? Thanks!
Liana,
  Normally you would just add dojo/on to your main requires in your app but if you do a separate require then your code that uses dojo on has to be inside the requires function.
require(["dojo/on"], function(on){
   //Now you can use "on"
roemhildtg
Your input's id is actually lyrSupport but you're looking for lyrSupports.
In index.html:
<input type="checkbox" id="lyrSupport" checked value="1" />    Supports
Change lyrSupport to lyrSupports.
StevenGraf1
I just replied to your other post and then saw this one.  Here was my response:
I checked out your toggle layer code and the code that you pulled from is using DynamicMapService found here Toggle layer visibility | ArcGIS API for JavaScript
In your application you are using feature layers.  I am using feature layers and toggling like this:
  1. var layer1 = new FeatureLayer("https://myurl/MapServer/1",{
  2.           mode: FeatureLayer.MODE_ONDEMAND,
  3.           outFields: ["*"],
  4.           infoTemplate: template
  5.         });
  6.
  7.   var checkBox = new CheckBox({
  8.   name: "checkBox1"
  9.   value: "agreed"
  10.   checked: false
  11.   onChange: function(b){
  12.   if (b == true) {
  13.   map.addLayer(layer1);
  14.   } else
  15.   map.removeLayer(layer1);
  16.   } }
  17.   }, "checkBox1").startup();
Be sure to call the "dijit/form/CheckBox", module with function(CheckBox)
  1. <input type='checkbox' id='checkBox1' value=1 />Layer1<br />
Hope this helps you out with that issue.
Steven
