How do I clear graphics after I close the balloon in the geocoding widget?
1699
11-14-2014 02:40 PM
ChrisSergent
When I search for an address, balloon appears to display that address. I would like the graphics to clear when I close the balloon. Below is the code with part of it commented out on how I thought I was supposed to do it. What do I need to change?
<!DOCTYPE html>
<html>
    <head>
        <title>Geocoder template</title>
        <meta http-equiv="content-type" content="text/html; charset=utf-8">
        <meta name="viewport" content="initial-scale=1,maximum-scale=1, user-scalable=no">
        <link rel="stylesheet" href="http://js.arcgis.com/3.11/dijit/themes/claro/claro.css">
        <link rel="stylesheet" href="http://js.arcgis.com/3.11/esri/css/esri.css">
        <style>
            html, body, #mapDiv
                padding:0;
                margin:0;
                height:100%;
            #search
                display:block;
                position:absolute;
                z-index:3;
                top:20px;
                left:75px;
        </style>
        <script src="http://js.arcgis.com/3.11/"></script>
        <script>
            var map;
            require(["esri/map",
                     "esri/dijit/Geocoder",
                     "esri/graphic",
                     "esri/symbols/SimpleMarkerSymbol",
                     "esri/geometry/screenUtils",
                     "esri/geometry/Extent",
                     "esri/layers/ArcGISDynamicMapServiceLayer",
                     "esri/layers/ArcGISTiledMapServiceLayer",
                     "dojo/dom",
                     "dojo/dom-construct",
                     "dojo/on",
                     "dojo/parser",
                     "dojo/query",
                     "dojo/_base/Color",
                     "dojo/domReady!"], function (Map, Geocoder, Graphic, SimpleMarkerSymbol, screenUtils, Extent, ArcGISDynamicMapServiceLayer, ArcGISTiledMapServiceLayer, dom, domConstruct, on, parser, query, Color
                         // declare initial map extent with spatial reference
                         var initialExtent = new Extent({ "xmin": 777229.03, "ymin": 1133467.92, "xmax": 848340.14, "ymax": 1185634.58, "spatialReference": { "wkid": 3435} });
                         map = new Map("mapDiv", {
                             showAttribution: false,
                             sliderStyle: "small",
                             extent: initialExtent
                         // begin geocoder
                         var geocoder = new Geocoder({
                            arcgisGeocoder:false,
                            geocoders: [{
                            url:"http://maps.decaturil.gov/arcgis/rest/services/Public/WebAddressLocator/GeocodeServer",
                            name: "Web Address Locator",
                            placeholder: "Find address",
                            outFields:"*"
                            map:map,
                            autoComplete:true,
                            }, dom.byId("search"));
                            geocoder.startup();
                        geocoder.on("select",showLocation);
//                        dojo.disconnect(Geocoder,'onClear',function(){
//                            removeGraphics();
//                       function removeGraphics() {
//                        map.graphics.clear();
                        function showLocation(evt) {
                           var point = evt.result.feature.geometry;
                           var symbol = new SimpleMarkerSymbol()
                                .setStyle("square")
                                .setColor([255,0,0,0.5]);
                           var graphic = new Graphic(point, symbol);
                           map.graphics.add(graphic);
                           map.infoWindow.setTitle("Search Result");
                           map.infoWindow.setContent(evt.result.name);
                           map.infoWindow.show(evt.result.feature.geometry);
                        // end geocoder
                         // add imagery
                         var tiled = new ArcGISTiledMapServiceLayer("http://maps.decaturil.gov/arcgis/rest/services/Aerial_2014_Tiled/MapServer");
                         map.addLayer(tiled);
                         // set operational layers
                         var operationalLayer = new ArcGISDynamicMapServiceLayer("http://maps.decaturil.gov/arcgis/rest/services/Public/InternetVector/MapServer", { "opacity": 0.5 });
                         // add operational layers
                         map.addLayer(operationalLayer);
        </script>
    </head>
    <body class="soria">
        <div id="search"></div>
        <div id="mapDiv"></div>
    </body>
</html>
SteveCole
Honored Contributor
Rather than the Geocode dijit, you could remove the graphic when the infoWindow is hidden:
                      map.infoWindow.on("hide", function () {
SteveCole
Honored Contributor
RobertScheitlin__GISP
Chris,
  Steves answer is correct. Here is the edited code with the clear event on the geocoder doing the same thing (hiding the map info window and clearing the maps graphics.
<!DOCTYPE html>
<html>
<head>
  <style>
    html,
    body,
    #mapDiv {
      padding: 0;
      margin: 0;
      height: 100%;
    #search {
      display: block;
      position: absolute;
      z-index: 3;
      top: 20px;
      left: 75px;
  </style>
  <script>
    var map;
             "esri/graphic",
             "dojo/dom",
             "dojo/on",
             "dojo/parser",
             "dojo/query",
             "dojo/_base/Color",
             "dojo/domReady!"
            function (
          "xmin": 777229.03,
          "ymin": 1133467.92,
          "xmax": 848340.14,
          "ymax": 1185634.58,
            "wkid": 3435
// begin geocoder
          arcgisGeocoder: false,
          geocoders: [{
            url: "http://maps.decaturil.gov/arcgis/rest/services/Public/WebAddressLocator/GeocodeServer",
            outFields: "*"
          map: map,
          autoComplete: true,
        geocoder.startup();
        geocoder.on("select", showLocation);
        geocoder.on("clear", function(){
          map.infoWindow.hide();
          .setStyle("square")
          .setColor([255, 0, 0, 0.5]);
          map.infoWindow.on('hide', function(){
// end geocoder
// add imagery
          "opacity": 0.5
  </script>
</head>
</body>
</html>
