How display map tools with @arcgis/map-components-react
1159
03-20-2025 07:31 AM
IrynaBabych
Map tools do not displayed when using mapRef.
const mapRef = useRef<HTMLArcgisMapElement>(null);
const graphicLayer = new GraphicsLayer();
const generateWebMap = async (map: MapType) => {
const mapEl = mapRef.current;
const webMap = await getWebMap(map.mapId);
if (webMap && mapEl) {
const mapView = new MapView({
map: webMap,
zoom: config.Zoom,
container: mapEl,
const sketch = new Sketch({
layer: graphicLayer,
view: mapView,
visibleElements: sketchVisibleElements,
setMapView(mapView);
setSketch(sketch);
sketch.on('create', handleSketchCreateAction);
sketch.on('update', handleSketchUpdateAction);
if (creationLayer) {
sketch.on('delete', handleSketchDeleteAction);
useEffect(() => {
const actualMapFromProject = maps?.[0];
if (mapRef?.current && actualMapFromProject) generateWebMap(actualMapFromProject);
<div css={styles.wrapper(isWebMapOpen || isChildTab)}>
<ArcgisMap ref={mapRef}>
<ArcgisEditor />
</ArcgisMap>
</div>
ReneRubalcava
Esri Frequent Contributor
If you can provide a github repo showing the issue, might be able to help. From your snippet, I'm not sure why you're creating a new MapView and using components, it should be one or the other.
If you use React 19, you don't need the map-components-react package.
Here is a React 19 sample
https://github.com/Esri/jsapi-resources/tree/main/component-samples/map-components/samples/react
Noah-Sager
Hi @IrynaBabych, there's an easier way to work with components, here's an example using Sketch:
<arcgis-map basemap="topo-vector" center="139.5716,35.696" zoom="18">
<arcgis-sketch position="top-right" creation-mode="update"> </arcgis-sketch>
</arcgis-map>
https://developers.arcgis.com/javascript/latest/sample-code/sandbox/?sample=sketch
