How can I Split A polygon and how can I merge serveral polygon
8674
8
08-12-2014 02:18 AM
xiaoyunnsongb
Dear superiors:
    Now I have a question to request ,please lost several minutes.
Q1: How can i split a polygon
   now   there is a polygon A,when i draw a line, then the polygon split to two (A1,A2).
                                      pic one
                                                             pic two
Q2:How can i merge serveral polygon to one
   now  there is two  or more than two polygons next (A1,A2) ,when I  press Ctrl key ,then  the polygons all be choiced ,how  can I merge then to one(A)
like the picture up  pic two ------> pic one
Tags (3)
JoshHevenor
You'll need the geometryService:
geometryservice-amd | API Reference | ArcGIS API for JavaScript
This will get you geometries and you can update/create your features for saving as required. Here's how I've done this.
Split:
- Start with a selected polygon (know what you're splitting)
- Use the draw toolbar to get a line (onDrawEnd Event)
- I use the GeometryService->trimExtend to make sure the line will cut completely
- Use geometryService->cut([selectedPoly], newLine, ...) to get two new polys
- save the new polys (add two new and delete old, or whatever works for your data)
Merge
- Select multiple polygons
- geometryService->union([selectedPolys]) to get one poly
- save the new poly (delete the old, add new, etc).
I haven't touched on managing the attributes, but that shouldn't be bad once you have the geometries:
BartSmit
there should be a 'merge' option in the menu on your editor toolbar. Make sure you have only features selected from the same layer otherwise the merge will not work.
xiaoyunnsongb
Dear Mr Bart Smit:
         Thanks very much.
  Is it   esri/dijit/editing/Editor? Yes in a  layer, How can i split the polygon?
                Best wishes
BartSmit
hhm, I'm afraid I spoke too soon. I can't find any code that has merge/split. All I can find is vertex/move/snap etc .. It might have been a geoprocessing service that offered that functionality. Or it might not have been esri stuff.. I can't recall the example. I'm sorry.
xiaoyunnsongb
Dear Bart Smit:
Also thanks to you。
xiaoyunnsongb
Superiors:
           My  function is  in javascript Of html ,not desktop, thanks very much。
MonyrothLy
U can use the cut polygon tool
xiaoyunnsongb
Dear monyrothly
       Thanks very much. But  I still  not  understand, Can you give the  component  in esri,
Wish  you happy every day.
JoshHevenor
Split:
Merge
