How can I get the map to repeat to fill the screen?
4795
03-13-2013 07:54 AM
JcFx
I'm programming my first ArcGIS application. I've created a simple map. When I zoom out to a world view, the map doesn't fill the width of the screen. Ideally I'd like it to repeat until the available space is filled. How can I do this?
Here's the code I have so far:
var map = new esri.Map("map", {
                basemap: "topo",
                center: [0, 0],
                zoom: 2
And here's the result:
[ATTACH=CONFIG]22575[/ATTACH]
How can I get the map to repeat to fill the white space on either side?
Many thanks in advance,
JcFx
StephenLead
Honored Contributor
To my knowledge, this isn't possible in the Esri JS API. At the developer summit 2 years ago, Jeremy mentioned that they didn't like the way Google Maps shows "multiple worlds" and that Esri approached it differently. (As an aside, I just noticed that Google Maps is no longer showing "multiple worlds" either.)
wraparound180 will mean that you can pan continuously east or west, but if you zoom out too far you'll see white space. A workaround is to prevent zooming out too far by specifying the Level of Details (LODs).
KenBuja
MVP Esteemed Contributor
Use wrapAround180 in the constructor. Note that
When true, supports continuous pan across the dateline. Wraparound is supported in the following cases:
  • Map spatial reference is WGS84 or Web Mercator
  • The tiling scheme is either the pre-9.3 ArcGIS Online (4326) tiling scheme or  ArcGIS/Google Maps/ Bing tiling scheme.
  • Dynamic services must be version 10 or greater.
  At version 3.1 the default value is true. For versions earlier than 3.1 the default value is false.
                basemap: "topo",
                center: [0, 0],
                zoom: 2
wrapAround180: true
JcFx
Ken,
Thanks for the speedy reply. I tried that, but it didn't work. How can I check if those criteria (spatial reference, tiling scheme, dynamic services version) are met? Is there a sample that shows how to set them for minimal horizontal wraparound? I'm working with v3.3 of the API, in case that is relevant.
My constructor now looks like this:
                basemap: "topo",
                center: [0, 0],
                zoom: 2,
                sliderPosition: "bottom-left",
                spatialRefence: new esri.SpatialReference({ "wkid": 3857 }),
                wrapAround180: true
JcFx
KenBuja
Yes, I'm seeing the same issue using the Create a map sample, with the zoom set to 2
StephenLead
Honored Contributor
JcFx
Actually Google Maps does still repeat (at least in Chrome, as of today), if you drag it into a wide enough, narrow enough configuration - they just manipulate the minimum zoom value so that it's rarely necessary. Thanks for the answer though, which is useful.
