How can I full screen display  map??
14279
12
05-01-2014 12:30 AM
by Anonymous User
Not applicable
Original User: xiaoyun8786
hello,every superior??
       I have a question,I hope you can lost several minute to look at it??if you can answer my question ??I thanks you very much???
My map is in right of center??now i should add a button  of ???full screen????? if i click the ??? full screen "button, the map display full screen, then  click it the second times, the map back.
    pic A  [ATTACH=CONFIG]33512[/ATTACH]  -- >     B  [ATTACH=CONFIG]33513[/ATTACH] , the yellow render is map  and  the green color is  IE head???
by Anonymous User
Not applicable
Original User: mariczone
Dear mariczone�?
[ATTACH=CONFIG]33547[/ATTACH] this is  after click Back , How can it click it to before [ATTACH=CONFIG]33548[/ATTACH]
U just need to create variable to save original map contain property-top,left,width,height.
On full screen method - U change property map to represent in fullscreen.
Then on back method u just need to set property map back to the original position that u saved.
see example on http://jsfiddle.net/7SY5q/11/
xiaoyunnsongb
Dear mariczone�?
      Thanks very very much that  you lost much time to answer my question. If   I can help you  songthing   Please tell me ,that I
am very glad.
       Wish you glad�?� happiness very day.
                 From  xiaoyun
                2014.5.2;)
xiaoyunnsongb
Dear
  Excute me. Can you lost a little time to look at  this  question :
   http://forums.arcgis.com/threads/109043-Draw-the-point-is-not-according-to-the-mouse-click
   Thanks very  much. Can I  have your e-mail? Thanks.
