How can I change the title attribute of the locate widget?
2098
05-31-2017 10:22 AM
JackFairfield
In the 4.x api, I want to change the title attribute of the dom element in the locate widget.  The default value is "Default map view" which sounds misleading to the user.
I was thinking of using jquery to target the "esri-locate" and "esri-icon-locate" classes like this:
$(".esri-locate, .esri-icon-locate").prop('title', 'your new title');
This works when I run it in the console, but I can't figure out in which event I should put this to make sure the dom element is available.  Any help would be appreciated.
arcgis api for javascript 4‌ widget location‌ event listener‌ widget configuration‌
RobertScheitlin__GISP
Jack,
   According to the widgets nls file the title is suppose to be "Find my location".
https://js.arcgis.com/4.3/esri/widgets/Locate/nls/Locate.js
So this seems to be a bug/issue with the 4.x API. You should open a bug for this with tech support.
JackFairfield
Thanks Robert Scheitlin, GISP,
I have reached out to ESRI and my understanding is that this will be fixed with the 4.4 release.
I am still looking for an event that fires after everything loads in the map.  Something similar to the "Load" event that was in the 3.x version of the api.  Any suggestions?
