Home Button Question
2115
09-25-2014 07:12 AM
ChrisHolmes
Good day everyone,
I used the following sample to display the home button: Home Button | ArcGIS API for JavaScript
Using the following css code:
#HomeButton {
         position: absolute;
         top: 95px;
         left: 20px;
         z-index: 50;
The button displays here:
If I change the css to this:
#HomeButton {
         position: absolute;
         top: 175px;
         left: 260px;
         z-index: 50;
Is there a way in the css that I can tie the home button to the map pane? Just not sure if how I am doing it is the correct way.
Chris
Tags (1)
TimWitt2
You need to put the homebutton div within the map div.
<div id="map">
<div id="HomeButton"></div>
</div>
I don't think you can tie it to the map within your CSS.
TimWitt2
<div id="map">
</div>
ChrisHolmes
Thanks Tim. I had this:
<div id="map" class="shadow roundedCorners" data-dojo-type="dijit.layout.ContentPane" data-dojo-props="region:'center'"></div>
When I should have had this:
</div>
Chris
TimWitt2
Glad we got it figured out
