Histogram Time Slider in Legacy Style
3454
12-11-2015 07:38 AM
Chang-HengYang
Hi all,
I tried to modify the sample code Histogram Time Slider | ArcGIS API for JavaScript  from AMD to Legacy style.
I found the histogram was not shown in the bottom in the application (link listed below). I am wondering if you could provide valuable opinions on the application.
The Histogram time slider application based on Legacy style
http://maps.nmt.edu/JSTest/Histogram/Histogram_Legacy.html
Hank
RickeyFight
Chang-HengYang
Rickey Fite,
Thank you for the references. I did use these references and created a application by Legacy style. However, the histogram was not shown in the bottom. Could you see the source code and show me the solution?
I work in the NM geological survey and have used the legacy style to create the webmap since I saw more applications designed by legacy style in geological surveys in the US.
Hank
Chang-HengYang
Hi all,
Has anyone created your web mapping application with Histogram Time Slider in Legacy style?
Could anyone share your application link?
Hank
RobertScheitlin__GISP
Hank,
   There is hardly anyone that is still using Legacy style. You would be best to quite using it yourself as 4.0 of the API will not allow Legacy style. You should start updating your apps to AMD style now.
