Highlight features layer if selected search result intersect with feature layer
3748
7
12-28-2020 03:55 PM
anuragmittal
I have added different features layer on map and have a working code to highlight the feature layer once user click on the map (I am using hitTest on mouse click event). But I am trying to do the same (highlight feature layer) once user searched an address and that address falls on one of feature layer. I am not able to make it work.
Here is my code snippet
			search.on("search-complete", function(event)
			    //take lat and long from Esri search if geometry type is point or polygon
			    let lat, longt;
			    if(event.results[0].results[0].feature.geometry.type == 'point') {
			        lat = event.results[0].results[0].feature.geometry.latitude;
			        longt = event.results[0].results[0].feature.geometry.longitude;
			    } else if(event.results[0].results[0].feature.geometry.type == 'polygon') {
			        lat = event.results[0].results[0].feature.geometry.centroid.latitude;
			        longt = event.results[0].results[0].feature.geometry.centroid.longitude;
			   let pointVar = new Point({
			        latitude:lat,
			        longitude:longt
				view.hitTest(pointVar).then(function(response)
				{//alert("test");
					console.log(response);
					if (response && response.results.length > 0 && response.results[0].graphic && response.results[0].graphic != undefined && response.results[0].graphic.attributes != undefined ) {
						let graphic = response.results[0].graphic;
						view.whenLayerView(graphic.layer).then(function(lyrView){
								if (highlightSelect) {
							highlightSelect.remove();
							highlightSelect = lyrView.highlight(graphic);
JohnGrayson
Esri Alum
You can watch for the MapView property called updating to be false.  You can directly watch this property, or for this use-case maybe use watchUtils which might be more appropriate.  The assumption is that after navigating to a search result the view will be updating, and you want to wait before interrogating via hitTest(...) or other.  You could skip this part and see if it works for your use-case, and then add it in if it doesn't quite work as you need.
// ALL updating PROPERTY CHANGES //
mapView.watch('updating', (updating) =>{
  console.log('Updating: ', updating);
// WHEN updating IS FALSE ONE TIME //
watchUtils.whenFalseOnce(mapView, 'updating', ()=> {
  console.log('View Not Updating');
anuragmittal
Hi Guys,
Even I tried emitting click event on search-complete event of search widget. But that also not working. Here is my code.
search.on('search-complete', function(event){
				let lat, longt;
			        latitude:lat,
			        longitude:longt
				var scrPt = view.toScreen(pointVar);
				view.emit('click', {bubbles: true, cancelable: true,mapPoint: pointVar,screenPoint: scrPt});
JohnGrayson
Esri Alum
In your first example you pass in a Point instead of ScreenPoint to hitTest(...), and in the second example you're not calling hitTest(...), so it's hard to tell what is going on.  Do you have a very simple codepen/jsbin/other showing the issue?
anuragmittal
Thank you John for the reply. After using ScreenPoint to hiTest() it works only if searched location is visible on screen window. I have set zoom level to 15, so if I searched an address that's not visible on viewable screen then it doesn't work.
Here is my updated code
			var search = new Search({
				view: view,
				//container:"searchDiv",
				popupEnabled: false,
				resultGraphicEnabled: false,
				enableHighlight: false,
				//allPlaceholder:'#rn:msg:CUSTOM_MSG_MAP_SEARCH_PLACEHOLDER#',
				sources: [customSearchSource, cityOwnedParcelSearch, waterTreatmentPlanSearch, waterProductionWellSearch, sampleStationSearch],
				includeDefaultSources: false,
				maxResults: 8,
				maxSuggestions: 8,
			    let lat, longt;
			        latitude:lat,
			        longitude:longt
				//selectedGraphic.geometry = webMercatorUtils.geographicToWebMercator(pointVar);
				view.hitTest(view.toScreen(pointVar)).then(function(response)
				search.clear();
JohnGrayson
Esri Alum
Correct, hitTest(..) only works with information in the current view since it's designed to work when the user interacts with the view.  Hard to tell without a codepen/jsbin of the exact interactions going on, but here are a few possible alternatives for you to explore:
- make sure Search is configured to place the user over the found result, wait for the view to finish updating, then call hitTest(...).
- use goTo(...) to place the view over the found result, wait for the view to finish updating, then call hitTest(...).
- use goTo(...) to place the view over the found result, wait for the view to finish updating, then use fetchFeatures to get all features and not just the first one.
- ask all the individual layer(s) if they have any data at the searched location by calling queryFeatures(...).
anuragmittal
Thank you John, I was thinking the same. I can't simulate this on codepen as all API are secured. I am new to ESRI GIS. Could you please guide me how to wait for the view to finish updating?
JohnGrayson
Esri Alum
anuragmittal
Perfect. watchUtils worked for me. Thank you a lot.
