Hiding selected Feature within Popup
1438
02-19-2024 07:05 AM
Charan
Hi Everyone,
So, Im currently able to hide the selected features by clicking ont he feature and hiding it within the custom action in the popup. However, after changing my api to 4.28, Im not able to do it anymore
view.when(() => {
            const oidField = "OBJECTID";
            const oidField3 = "ObjectID";
            view.popup.on("trigger-action", ({ action }) => {
              if (action.id === "hide-this") {
                const oid = view.popup.selectedFeature.attributes[oidField3];
                Amicaoids.push(oid);
                Amicaexp = `${oidField3} NOT IN (${Amicaoids.join(",")})`;
                AmicaExistingSites.definitionExpression = Amicaexp;
                view.popup.close();
              } else if (action.id === "hide-pipeline") {
                const pipeline_oid =
                  view.popup.selectedFeature.attributes[oidField];
                Pipelineoids.push(pipeline_oid);
                Pipelinexp = `${oidField} NOT IN (${Pipelineoids.join(",")})`;
                Pipeline.definitionExpression = Pipelinexp;
                view.popup.close();
              } else if (action.id === "hide-sitelog") {
                const siteLog_oid =
                SiteLogoids.push(siteLog_oid);
                SiteLogexp = `${oidField} NOT IN (${SiteLogoids.join(",")})`;
                SiteLog.definitionExpression = SiteLogexp;
                view.popup.close();
              } else if (action.id === "hide-posite") {
                const posite_oid =
                POSiteoids.push(posite_oid);
                POSiteexp = `${oidField} NOT IN (${POSiteoids.join(",")})`;
                POSite.definitionExpression = POSiteexp;
                view.popup.close();
              } else if (action.id === "hide-comp") {
                const existing_oid =
                CompExistingoids.push(existing_oid);
                CompExistingexp = `${oidField} NOT IN (${CompExistingoids.join(
                CompetitorsExisting.definitionExpression = CompExistingexp;
                view.popup.close();
              } else if (action.id === "hide-qualified") {
                const qualified_oid =
                CompQualifiedoids.push(qualified_oid);
                CompQualifiedexp = `${oidField} NOT IN (${CompQualifiedoids.join(
                CompetitorsQualified.definitionExpression = CompQualifiedexp;
                view.popup.close();
              } else if (action.id === "hide-proposed") {
                const proposed_oid =
                CompProposedoids.push(proposed_oid);
                CompProposedexp = `${oidField} NOT IN (${CompProposedoids.join(
                CompetitorsProposed.definitionExpression = CompProposedexp;
                view.popup.close();
Tags (3)
JoelBennett
MVP Regular Contributor
Perhaps simplifying the syntax of your definition expressions might help. For example:
Amicaexp = oidField3 + " NOT IN(" + Amicaoids.join(",") + ")";
Charan
Hi @JoelBennett, the issue is that when I click on the popup, I don’t see the actions I have created!
JoelBennett
In that case, can you supply the code where you create the PopupTemplate and its actions?
