Hiding Multiple Feature Layers
1059
10-25-2011 01:51 PM
BenReilly
Is there a way to use layer.hide(); for multiple layers in a single function? I need to hide several layers at once, and the order they're in seems to be affecting its function. I have this:
   bikeLayer.hide();
   mopedLayer.hide();
   atmLayer.hide();
   recLayer.hide();
   foodLayer.hide();
as part of a larger function. if bikeLayer is turned on, I can hide it. if only atmLayer is on, it won't shut off, with the error that bikeLayer is not defined. How can I do this?
StephenLead
Honored Contributor
Is there a way to use layer.hide(); for multiple layers in a single function?... if only atmLayer is on, it won't shut off, with the error that bikeLayer is not defined
Hi Ben,
You could define an array of layers, and add each layer to the array when it is defined. Then iterate through the array and switch off each layer.
Something like this:
//define the array of layers - add each layer as it's created
var mapLayers = [];
mapLayers.add(bikeLayer);
mapLayers.add(atmLayer); //etc
//To switch off the layers
for (var i = 0; i < mapLayers.length - 1; i++) {
  mapLayers.hide()
Hope this helps,
Steve
