[HELP ME PLEASE] Can't run example from desktop !!!!
1299
07-30-2013 05:04 AM
PhuongNguyen_Thanh
Hi everybody ! First word I wish you have a good and happy working day !!!!! ^^
I have a problem that I'm so stressful. I downloaded a file from this site :
http://developers.arcgis.com/en/javascript/sandbox/sandbox.html?sample=map_webmap
and I can't run it from my PC. It displays a white page, nothing appears. I just only run it on that example's website
So can anyone can help me to solve this problem ? Many thanks 🙂
p/s: Internet is ok
BenFousek
You must run an application on a web server. This won't work: file:///C:/index.html. Must be HTTP protocol.
There are several development software packages out there like XAMPP http://www.apachefriends.org/en/xampp.html.
PhuongNguyen_Thanh
Thank you for your solution. I already installed XAMPP but I can't config how to run my downloaded file. Could you guide me how to config the XAMPP to run my downloaded file ?
Many thanks 🙂
BenFousek
Assuming you installed xampp at C:\xampp. There should be a folder C:\xampp\htdocs. Create a new folder in htdocs called 'MyApp' and copy the files there. Then in your browser go to: http://localhost/MyApp/index.html.
Also you must start Apache in XAMPP Control Panel (xampp-control.exe).
PhuongNguyen_Thanh
You are my savior 🙂 thank you so much ^^
