Heat Map visibility order
2862
01-31-2016 10:26 AM
MohamedNabil1
I have point and polygon feature layers on my map. the point layer order is over the polygon layer order.
Once I have changed the renderer of the point feature layer to heatmap renderer using JavaScript, it is always appear under the polygon layer.
This also happen on the ArcGIS online, Is this a bug or normal?
TyroneBiggums
Before 4.x, the graphicLayerIds collection will appear on top of the layerIds collection. If you find a way to have a graphicLayer show up, on the map, behind another layer type, let me know.
