Grid click function in this module says it's not defined
4020
08-11-2015 09:43 AM
TracySchloss
Honored Contributor
I have a grid that needs a click event.  The grid populates fine, but the click event isn't hooked up correctly.  I thought I could reference other functions in my modules, but instead it tells me it isn't defined.  I know sometimes if the function you're calling has a problem, it will act like the function isn't there, but I tried commenting out everything but a single line that made a console.log call and it still says "Uncaught ReferenceError: executeSpecialtySearch is not defined.
define([
"dojo/dom",
"dojo/on",
"dojo/dom-class",
"dojo/dom-construct",
"dojo/_base/array",
"dojo/store/Memory",
"esri/tasks/QueryTask",
"esri/tasks/query",
"extras/codeLookup"
], function(
dom, on, domClass, domConstruct, arrayUtils, Memory, QueryTask, Query, codeLookup){
    return {
        createSpecialtyList: function(catCode, dataGrid, crossRefTable){
            if (domClass.contains('specialtyDiv', 'div-visible')) {
                domClass.toggle('specialtyDiv', 'div-visible');
            var data;
            var query = new Query();
            var whereClause = "ID_CATEGORY_TYPE_FK" + " = '" + catCode + "'";
            query.where = whereClause;
            query.outFields = ['ID_SPECIALTY_FK'];
            query.returnDistinctValues = true;
            var qTask = new QueryTask(crossRefTable.url);
            qTask.execute(query, function(results){
                var data = arrayUtils.map(results.features, function(feature){
                    return {
                        'id': feature.attributes.ID_SPECIALTY_FK,
                        'name': codeLookup.findSpecDesc(feature.attributes.ID_SPECIALTY_FK),
                        'value': feature.attributes.ID_SPECIALTY_FK
                var currentMemory = new Memory({
                    data: data,
                    idProperty: 'id'
                var specDropdown = new dataGrid({
                    selectionMode: 'single',
                    store: currentMemory,
                    showHeader: false,
                    cellNavigation: false,
                    columns: {
                        "id": "id",
                        "name": "name",
                        "value": "value"
                    renderRow: function(obj){
                        var divNode = domConstruct.create('div', {
                            className: obj.name
                        domConstruct.place(document.createTextNode(obj.name), divNode);
                        return divNode;
                }, "specialtyDiv");
                specDropdown.on('.dgrid-row:click', function(event){
                    row = specDropdown.row(event);
                    var specCode = [row.data.value][0];
                    var specDesc = [row.data.name][0];
                    specType = specDesc;
                    //    console.log("Searching:  " + catDesc + ", cat Code:  " + catCode);
                    executeSpecialtySearch(specCode);  //fails here
                specDropdown.addKeyHandler(13, function(event){  //added for Keyboard event
                specDropdown.startup();
                specDropdown.sort('name');
            return data;
        emptySpecDropdown: function(){
            specType = "";
            domConstruct.empty(dom.byId('specialtyDiv'));
            dom.byId('specHeader').innerHTML = "";
            if (domClass.contains('specialtyDiv', 'dgrid')) {
                domClass.remove(dom.byId('specialtyDiv'), "dgrid dgrid-grid");
        executeSpecialtySearch: function(specCode){
            var initWhereClause = app.featureLayer.getDefinitionExpression();
            var appendSpecClause = "ID_SPECIALTY_FK" + " = '" + specCode + "'";
            var newWhereClause = "(" + appendSpecClause + ") AND (" + initWhereClause + ")";
            app.featureLayer.setDefinitionExpression(newWhereClause);
            var txt = searchType + "; " + specType;
            dom.byId('subHeader').innerHTML = "Medicaid Provider Search: " + txt;
            dom.byId('gridHeader').innerHTML = txt + " providers available in this area."
I'm confused when I should separate the functions with this syntax:
functionName: function (myParam) {
myOtherFunction : function (myotherParam){
and when I should leave it more like
myinitFunction: function (myParam) {
     myNestedFunction(myParam) {
It seems like the first style is what you'd use if you were wanted to group a few sets of functions together and called externally and the other when the functions are more internal.
TracySchloss
Honored Contributor
I changed the location/syntax of executeSpecialtySearch: function(specCode){ to be within createSpecialtyList
as
return {
            var specType = "";
            var data;
            function executeSpecialtySearch(specCode){
It was a scope problem, I just needed to study it a bit more.
ChrisSmith7
Honored Contributor
It looks like a scoping issue - what happens if you make the function global?
TracySchloss
Honored Contributor
as
return {
            var specType = "";
            var data;
ChrisSmith7
Honored Contributor
Tracy,
I wasn't sure if you were looking to nest it there - do you think you'll ever want to access the method as part of this module without being in context of createSpecialtyList?
TracySchloss
Honored Contributor
No, I don't think so.  The functionality is particular to that one grid.
