GraphicsLayer removeall graphics come back after zoom
2354
12-14-2017 02:58 PM
XueGao2
I'm using JavaScript API 4.5 and my application is using webmap. I want to highlight the feature that the user clicks on (polygon) and clear the current one and highlight the new one every time the user clicks on a new feature.
I created a GraphicsLayer for it and use removeall() to remove all the graphics before draw the new one. This works fine until I zoom the map. When I zoom the map all the graphics come back and I can't figure out where they are stored. I checked the graphics layer and there is always one graphic in it which is the most recent selected feature.
highlightFeature(graphic) {
 let theComponent = this;
 let graphicsLayerMap;
 theComponent.mapService.webMaps[theComponent.mapService.currentMap].layers.items.forEach(function(layer){
  if (layer.type === 'graphics') {
    graphicsLayerMap = layer;
 // SimpleFillSymbolProperties only necessary because of tight coupling of object types. Normally outside of Angular/Webpack we wouldn't need a fake SimpleFillSymbolProperties class
 let symbolProps = new SimpleFillSymbolProperties({
  style: 'none',
  outline: {
   width: 2,
   color: [0, 197, 255, 1]
 let highlightSymbol = new SimpleFillSymbol(symbolProps);
 graphic.symbol = highlightSymbol;
 if (graphicsLayerMap !== undefined) {
  // not the first time click on the map
  graphicsLayerMap.removeAll();
  graphicsLayerMap.add(graphic);
  } else {
  // if this is the first click on this map, add a graphicsLayer to the map
  // add graphic to GraphicsLayer
  let graphicsLayer = new GraphicsLayer({
   graphics: [graphic],
   listMode: 'hide'
  this.mapService.webMaps[this.mapService.currentMap].layers.add(graphicsLayer);
 Any help would be appreciated!
XueGao2
I figured this one out. The graphic parameter that's passing in is a Graphic. In 4.x, it has a property - layer which is "references the layer in which the graphic is stored." and this is the layer that I'm clicking on. So I guess it adds the graphic to the layer that I click on. I also add it to the GraphicsLayer and I'm clearing it every time I click on the map. So there are two graphics I think.
The solution is to just pass in the geometry of the graphic and create a Graphic in highlightFeature(). Then add the new graphic to the GraphicsLayer. !
highlightFeature(geometry) {
    let firstClick = true;
      style: 'none',
      outline: {
        width: 2,
    // Create a graphic and add the geometry and symbol to it
    let graphic = new Graphic({
      geometry: geometry,
      symbol: highlightSymbol
    // check to see if the graphics layer exists already
        layer.removeAll();
        layer.add(graphic);
        firstClick = false;
    if (firstClick) {
      // first time click on this webmap
      // add graphiclayer to the webmap
      let graphicsLayerMap = new GraphicsLayer({
        listMode: 'hide'
      theComponent.mapService.webMaps[this.mapService.currentMap].layers.add(graphicsLayerMap);
      // add graphic to the graphicslayer
