Graphics without a base map
5486
10
08-24-2012 02:34 AM
VladimirElistratov
I am unable to use graphics without a base map.
It's written in the doc for Map.onLoad:
Fires when the first or base layer has been successfully added to the map.
So I do the following:
dojo.connect(map,"onLoad", init);
var graphics = new esri.layers.GraphicsLayer();
map.addLayer(graphics);
But I'm getting an error after map.addLayer(graphics):
Uncaught TypeError: Cannot read property '_surface' of null
How can I use graphics without a base map?
Vladimir
JeffPace
MVP Alum
excellent derek thanks for the answer and links
vvoovv if you feel like derek (Swingley) answered your question, please click the little check mark on the right side of his post to mark it as "answered"
