Graphic Moves in Graphic Layer
1040
02-03-2011 01:06 PM
JaclynGorman
I have 2 graphic layers in my code.  They are both created by drawing on the map.  Basically there are 2 drawing toolbars.  I wanted users to be able to clear one graphics layer or the other independently.  The code works, but the graphics in the layer move when I pan around the map.  If I take away the graphics layers, the graphics do not move when I pan.  Are there any ideas on what would cause this?  Thanks
Jaclyn
JaclynGorman
I think I finally figured this out.  Apparently with the graphics layers,unlike most layers, you have to wait for the map to load before adding a new GraphicsLayer.
For example:
you can't just have
var NewGraphics
NewGraphics = new esri.layers.GraphicsLayer({});
map.addLayer(NewGraphics);
Instead you have to have
  dojo.connect(map, "onLoad", function() {
