Getting x and y coordinates of a graphic on a feature layer when clicking it
3863
7
03-17-2014 05:53 AM
ChristianDebono
I have a feature layer with a set of points in it. I want to get the x and y coordinates of a specific graphic when clicking it. I have done the following code but it is not giving the exact location.
on(map, "dbl-click", getCoordinates);  function getCoordinates(event) {                  var mp = esri.geometry.webMercatorToGeographic(event.mapPoint);                 alert(mp.x.toFixed(6) + ", " + mp.y.toFixed(6));                                                              }
[ATTACH=CONFIG]32230[/ATTACH]
I want to get the coordinates of the "M" symbol when the user clicks it.
Thanks for your help
JakeSkinner
Esri Esteemed Contributor
Try the following:
function selectInBuffer(response){   var feature;   var features = response.features;   var inBuffer = [];    for (var i = 0; i < features.length; i++) {     feature = features;     if(polygon.contains(feature.geometry)){       inBuffer.push(feature.attributes[featureLayer.objectIdField]);     }   }   var query = new Query();   query.objectIds = inBuffer;    featureLayer.selectFeatures(query, FeatureLayer.SELECTION_NEW, function(features, index){                     for(var i = 0; i < features.length; i++){           alert(features.geometry.x + ", " + features.geometry.y)       }   })           }
JakeSkinner
Hi Christian,
You can fire the 'getCoordinates' function when only the Feature Layer is clicked.  Ex:
var featureLayer = new FeatureLayer("http://sampleserver6.arcgisonline.com/arcgis/rest/services/USA/MapServer/0",{
    mode: FeatureLayer.MODE_ONDEMAND,
map.addLayer(featureLayer);
on(featureLayer, "click", getCoordinates);
ChristianDebono
Thanks a lot, worked perfectly
ChristianDebono
Is it possible to get the x and y coordinates of a specific point with out clicking it. For instance I written this code but it is not working.
featureLayer.selectFeatures(query, FeatureLayer.SELECTION_NEW, function (features, index) {
                    var xLat = "";
                    for (var x = 0; x < features.length; x++) {
                        xLat = features.geometry.extent.xmax;
JakeSkinner
Yes, it's possible.  How are you selecting which point you want the coordinates for?  How do you want the coordinates returned (i.e. alert, dgrid)?
ChristianDebono
I'm selecting it by drawing a free hand polygon. A simple alert is enough. Below I have the code for selection
 function selectInBuffer(response) {
                var feature;
                var inBuffer = [];
                    feature = features;
                    if (polygon.contains(feature.geometry)) {
                    dom.byId('resultDiv').innerHTML = "Number of meters within polygon:  <b>" + features.length + "</b>";
                    var xLat= "";
JakeSkinner
Try the following:
ChristianDebono
Thanks for your help, worked perfectly!
