Getting the Table of Contents (TOC) to work with the Template Picker/Editor
1910
07-18-2013 05:00 PM
IanPeebles
Has anyone been able to add in a template picker/editor to a pane based on the sample below?
http://gmaps-utility-gis.googlecode.com/svn/tags/agsjs/2.04/examples/toc.html
I have been able to get a similar TOC sample to work (shown above), but cannot get a template picker/editor toolbar to work properly within the frames.
Here is the template picker and editor I am trying to add into a pane from the first sample:
http://developers.arcgis.com/en/javascript/samples/ed_simpletoolbar/
Essentially, I am trying to get both of these samples to work together, but have been unsuccessful.  I will see if I can put together a sample and attach the code.
MustafaOgurlu
Hi Ian,
I modified code for you. But there is a problem. Feature Layer couldn't show properly at the toc.
<!DOCTYPE html>
<html>
<head>
    <meta http-equiv="Content-Type" content="text/html; charset=utf-8">
    <meta http-equiv="X-UA-Compatible" content="IE=7, IE=9, IE=10">
    <!--The viewport meta tag is used to improve the presentation and behavior of the samples
      on iOS devices-->
    <meta name="viewport" content="initial-scale=1, maximum-scale=1,user-scalable=no">
    <title>Edit rivers and waterbodies</title>
    <link rel="stylesheet" href="http://serverapi.arcgisonline.com/jsapi/arcgis/3.5/js/dojo/dijit/themes/claro/claro.css">
    <link rel="stylesheet" href="http://serverapi.arcgisonline.com/jsapi/arcgis/3.5/js/esri/css/esri.css" />
    <style>
        html, body
            height: 100%;
            width: 100%;
            margin: 0;
            overflow: hidden;
        #map
            padding: 0;
        #header
            font-size: 14pt;
            padding-left: 20px;
            padding-top: 4px;
            color: #660000;
        .dj_ie .infowindow .window .top .right .user .content
            position: relative;
        .dj_ie .simpleInfoWindow .content
            position: relative;
    </style>
    <script type="text/javascript">
        var djConfig = {
            parseOnLoad: true,
            packages: [{
                "name": "agsjs",
                "location": location.pathname.replace('/\/[^/]+$/', "") + '/../js/agsjs'
    </script>
    <script src="http://serverapi.arcgisonline.com/jsapi/arcgis/3.5/"></script>
    <script>
        dojo.require("dijit.layout.BorderContainer");
        dojo.require("dijit.layout.ContentPane");
        dojo.require("esri.map");
        dojo.require("esri.dijit.editing.Editor-all");
        dojo.require("esri.SnappingManager");
        dojo.require("agsjs.dijit.TOC");
        var map;
        function init() {
            //snapping is enabled for this sample - change the tooltip to reflect this
            esri.bundle.toolbars.draw.start = esri.bundle.toolbars.draw.start + "<br/>Press <b>ALT</b> to enable snapping";
            //This sample requires a proxy page to handle communications with the ArcGIS Server services. You will need to
            //replace the url below with the location of a proxy on your machine. See the 'Using the proxy page' help topic
            //for details on setting up a proxy page.
            esri.config.defaults.io.proxyUrl = "/proxy";
            //This service is for development and testing purposes only. We recommend that you create your own geometry service for use within your applications.
            esri.config.defaults.geometryService = new esri.tasks.GeometryService("http://tasks.arcgisonline.com/ArcGIS/rest/services/Geometry/GeometryServer");
            map = new esri.Map("map", {
                basemap: "satellite",
                center: [-96.541, 38.351],
                zoom: 14,
                slider: false
            dojo.connect(map, "onLayersAddResult", initEditor);
            //add boundaries and place names
            var labels = new esri.layers.ArcGISTiledMapServiceLayer("http://server.arcgisonline.com/ArcGIS/rest/services/Reference/World_Boundaries_and_Places/MapServer");
            map.addLayer(labels);
            var rivers = new esri.layers.FeatureLayer("http://sampleserver3.arcgisonline.com/ArcGIS/rest/services/Hydrography/Watershed173811/FeatureServer/1", {
                mode: esri.layers.FeatureLayer.MODE_ONDEMAND,
                outFields: ['*']
            var waterbodies = new esri.layers.FeatureLayer("http://sampleserver3.arcgisonline.com/ArcGIS/rest/services/Hydrography/Watershed173811/FeatureServer/0", {
                outFields: ['*']
            map.addLayers([waterbodies, rivers]);
            dojo.connect(map, 'onLayersAddResult', function (results) {
                var toc = new agsjs.dijit.TOC({
                    map: map,
                    layerInfos: [{
                        layer: labels,
                        title: "labels",
                        slider: true,
                        collapsed: true
                        layer: rivers,
                        title: "rivers",
                        slider: true,
                        collapsed: true
                        layer: waterbodies,
                        title: "waterbodies",
                        slider: true,
                        collapsed: true
                }, 'tocDiv');
                toc.startup();
        function initEditor(results) {
            var templateLayers = dojo.map(results, function (result) {
                return result.layer;
            var templatePicker = new esri.dijit.editing.TemplatePicker({
                featureLayers: templateLayers,
                grouping: true,
                rows: 'auto',
                columns: 3
            }, 'templateDiv');
            templatePicker.startup();
            var layers = dojo.map(results, function (result) {
                return { featureLayer: result.layer };
            var settings = {
                map: map,
                templatePicker: templatePicker,
                layerInfos: layers,
                toolbarVisible: true,
                createOptions: {
                    polylineDrawTools: [esri.dijit.editing.Editor.CREATE_TOOL_FREEHAND_POLYLINE],
                    polygonDrawTools: [esri.dijit.editing.Editor.CREATE_TOOL_FREEHAND_POLYGON,
              esri.dijit.editing.Editor.CREATE_TOOL_CIRCLE,
              esri.dijit.editing.Editor.CREATE_TOOL_TRIANGLE,
              esri.dijit.editing.Editor.CREATE_TOOL_RECTANGLE
                toolbarOptions: {
                    reshapeVisible: true
            var params = { settings: settings };
            var myEditor = new esri.dijit.editing.Editor(params, 'editorDiv');
            //define snapping options
            var symbol = new esri.symbol.SimpleMarkerSymbol(esri.symbol.SimpleMarkerSymbol.STYLE_CROSS, 15, new esri.symbol.SimpleLineSymbol(esri.symbol.SimpleLineSymbol.STYLE_SOLID, new dojo.Color([255, 0, 0, 0.5]), 5), null);
            map.enableSnapping({
                snapPointSymbol: symbol,
                tolerance: 20,
                snapKey: dojo.keys.ALT
            myEditor.startup();
        dojo.ready(init);
    </script>
</head>
<body class="claro">
    <div id="main" data-dojo-type="dijit.layout.BorderContainer" data-dojo-props="design:'headline'"
        style="height: width:100%; height: 100%;">
        <div data-dojo-type="dijit.layout.ContentPane" id="header" data-dojo-props="region:'top'">
            Edit Hydrography
        </div>
        <div data-dojo-type="dijit.layout.ContentPane" data-dojo-props="region:'left'" style="width: 300px;
            overflow: hidden;">
            <div id="templateDiv">
            </div>
            <div id="editorDiv">
            </div>
        </div>
        <div data-dojo-type="dijit.layout.ContentPane" id="map" data-dojo-props="region:'center'">
        </div>
        <div dojotype="dijit.layout.ContentPane" id="leftPane" region="right" style="visibility: visible;
            width: 300px;">
            <div dojotype="dijit.layout.ContentPane" id="legendPane" title="Lejant" selected="true">
                <div data-dojo-type="dijit.layout.AccordionContainer">
                    <div data-dojo-type="dijit.layout.ContentPane" title="Tabakalar" selected="true">
                        <div id="tocDiv">
                        </div>
                    </div>
                </div>
            </div>
        </div>
    </div>
</body>
</html>
IanPeebles
Hi Ian,
<!DOCTYPE html>
<html>
<head>
      on iOS devices-->
    <style>
        html, body
            height: 100%;
            width: 100%;
            margin: 0;
            overflow: hidden;
        #map
            padding: 0;
        #header
            font-size: 14pt;
            padding-left: 20px;
            padding-top: 4px;
            color: #660000;
            position: relative;
            position: relative;
    </style>
        var djConfig = {
            parseOnLoad: true,
            packages: [{
                "name": "agsjs",
    </script>
    <script>
        var map;
        function init() {
                zoom: 14,
                slider: false
                outFields: ['*']
                outFields: ['*']
                    map: map,
                    layerInfos: [{
                        layer: labels,
                        title: "labels",
                        slider: true,
                        collapsed: true
                        layer: rivers,
                        title: "rivers",
                        slider: true,
                        collapsed: true
                        layer: waterbodies,
                        slider: true,
                        collapsed: true
                }, 'tocDiv');
                toc.startup();
                grouping: true,
                rows: 'auto',
                columns: 3
            }, 'templateDiv');
            var settings = {
                map: map,
                layerInfos: layers,
                createOptions: {
                toolbarOptions: {
                tolerance: 20,
            myEditor.startup();
        dojo.ready(init);
    </script>
</head>
            Edit Hydrography
        </div>
            overflow: hidden;">
            </div>
            </div>
        </div>
        </div>
            width: 300px;">
                        <div id="tocDiv">
                        </div>
                    </div>
                </div>
            </div>
        </div>
    </div>
</body>
</html>
Thanks for the reply.  I copied this sample to my machine and tried to run, but this is what I get in my browser:
IanPeebles
I cannot seem to get the template picker to work using an accordion pane.  Here is a sample I have put together.  My goal is to put the TOC in one pane and the template picker and editor in another pane.  Anyone have any ideas?  Below is a copy of the code:
<!DOCTYPE html>
<html>
<head>
      on iOS devices-->
    <title>Legend and Map</title>
    <style>
        html, body
            height: 100%;
            width: 100%;
            margin: 0;
            overflow: hidden;
        #map
            padding: 0;
        #header
            font-size: 14pt;
            padding-left: 20px;
            padding-top: 4px;
            color: #660000;
  #leftPane {
    width: 25%;
            position: relative;
            position: relative;
    </style>
        var djConfig = {
            parseOnLoad: true,
            packages: [{
                "name": "agsjs",
                //"location": location.pathname.replace('/\/[^/]+$/', "") + '/../js/agsjs'
    "location": 'http://arcgis02/gmaps-utility-gis/agsjs' // for xdomain load
    </script>
    <script>
  //dojo.require("dijit.layout.AccordionContainer");
        var map;
        function init() {
                zoom: 14,
                slider: false
            // Add Map Service and Feature Layers
   var hydrographywatershed = new esri.layers.ArcGISDynamicMapServiceLayer("http://sampleserver3.arcgisonline.com/ArcGIS/rest/services/Hydrography/Watershed173811/MapServer");
   //map.addLayer(basemap);
            var rivers = new esri.layers.FeatureLayer("http://sampleserver3.arcgisonline.com/ArcGIS/rest/services/Hydrography/Watershed173811/FeatureServer...", {
                outFields: ['*']
            var waterbodies = new esri.layers.FeatureLayer("http://sampleserver3.arcgisonline.com/ArcGIS/rest/services/Hydrography/Watershed173811/FeatureServer...", {
                outFields: ['*']
                    map: map,
                    layerInfos: [{
         layer: hydrographywatershed,
                        title: "hydrographywatershed",
                        collapsed: false
                        layer: labels,
                        title: "labels",
                        collapsed: true
                        layer: rivers,
                        title: "rivers",
                        collapsed: true
                        layer: waterbodies,
                        collapsed: true
                }, 'tocDiv');
                toc.startup();
                grouping: true,
                rows: 'auto',
                columns: 3
            }, 'templateDiv');
            var settings = {
                map: map,
                layerInfos: layers,
                createOptions: {
                toolbarOptions: {
                tolerance: 20,
            myEditor.startup();
        dojo.ready(init);
    </script>
</head>
    <div id="main" data-dojo-type="dijit.layout.BorderContainer" data-dojo-props="design:'headline'" style="height: width:100%; height: 100%;">
<!-- Application Header -->
    TOC Legend and Editing Template Picker and Toolbar
    </div>
   <!-- Table of Contents -->
   <div id="leftPane" data-dojo-type="dijit.layout.ContentPane" data-dojo-props="region:'left'">
    <!-- According Container -->
      <!-- Legend Pane -->
      <div data-dojo-type="dijit.layout.ContentPane" id="legendPane" data.dojo.props="title:'Legend', selected:true">
       <div id="tocDiv"></div>
      </div>
     <!-- Editing Content Pane -->
     <div data-dojo-type="dijit.layout.ContentPane" id="editingPane" data.dojo.props="title:'Editing Tools'">
      Template Picker
      <div id="templateDiv"></div>
      Editing Toolbar
      <div id="editorDiv"></div>
     </div>
    </div>
   </div>
<!-- Map -->
<div data-dojo-type="dijit.layout.ContentPane" id="map" data-dojo-props="region:'center'"></div>
    </div>
</body>
</html>
IanPeebles
I think I got it working.  For those who are interested, have a look at this sample:
<!DOCTYPE html>
<html>
<head>
      on iOS devices-->
    <style>
        html, body
            height: 100%;
            width: 100%;
            margin: 0;
            overflow: hidden;
        #map
            padding: 0;
        #header
            font-size: 14pt;
            padding-left: 20px;
            padding-top: 4px;
            color: #660000;
  #leftPane {
    width: 25%;
            position: relative;
            position: relative;
    </style>
        var djConfig = {
            parseOnLoad: true,
            packages: [{
                "name": "agsjs",
    </script>
    <script>
        var map;
        function init() {
                zoom: 14,
                slider: false
                outFields: ['*']
                outFields: ['*']
                    map: map,
                    layerInfos: [{
                        collapsed: false
                        layer: labels,
                        title: "labels",
                        collapsed: true
                        layer: rivers,
                        title: "rivers",
                        collapsed: true
                        layer: waterbodies,
                        collapsed: true
                }, 'tocDiv');
                toc.startup();
                grouping: true,
                rows: 'auto',
                columns: 3
            }, 'templateDiv');
            var settings = {
                map: map,
                layerInfos: layers,
                createOptions: {
                toolbarOptions: {
                tolerance: 20,
            myEditor.startup();
        dojo.ready(init);
    </script>
</head>
    </div>
  <div data-dojo-type="dijit/layout/AccordionContainer">
   <div data-dojo-type="dijit/layout/ContentPane" title="Legend">
   </div>
   <div data-dojo-type="dijit/layout/ContentPane" title="Editor Pane" selected="true">
     TemplateDiv
     EditorDiv
   </div>
   <div data-dojo-type="dijit/layout/ContentPane" title="Geocoding">
   </div>
  </div>
</div>
<!-- Map -->
    </div>
</body>
</html>
melissaGomez
Hello,
I was using your previous example to build my TOC/Legend Widget and I got it up and running, but now I am having trouble getting my Accordion Container to appear. Everything is showing all at once in my legend.
How did you get your accordion container to continue working with the TOC?
Here is my code:
<!--Start All Div Tags in Left Pane for Accordion Container-->
      <div data-dojo-type="dijit.layout.ContentPane" data-dojo-props="region:'left'" id="leftPane">
        <div data-dojo-type="dijit.layout.ContentPane" data-dojo-props="title:'Legend'">
          Political Boundaries
<!--add legend here-->
           data-dojo-props="title:'Legend', selected:true">
        <!--<div id="legendDiv"></div>-->
  <div id="tocDiv">
      </div>
      </div>
<!--end adding legend here-->
<!--start adding print button here-->
       <div data-dojo-type="dijit.layout.ContentPane" data-dojo-props="title:'Print'">
           <div id="printButton">
    </div>
    </div>
<!--end print button here-->
<!--start bookmark here-->
        <div data-dojo-type="dijit.layout.ContentPane" data-dojo-props="title:'Bookmark'">
          <div id="bookmark"></div>
        </div>
      </div>
      </div>
    </div>
<!--end bookmark here-->
<!--End all Div Tags in Left Pane for Accordion Container-->
Please help, thanks..
