Getting some problem when we call toScreen() method
1104
08-21-2022 10:19 PM
GrowthLadder
We are going to get the ScreenPoint of a MapPoint. When we are using the map-point as center of the map and then using the toScreen() method then we are getting the ScreenPoint with the value of x & y as NaN. We are using the API version 3.x
Please help why the x and y property value is NaN
JoelBennett
MVP Regular Contributor
Without seeing your code, it's impossible to tell what's causing the problem.  However, to accomplish what you're trying to do, I would recommend something like the following:
var mapCenter = map.extent.getCenter();
var screenCenter = map.toScreen(mapCenter);
console.info(screenCenter.x.toString() + ", " + screenCenter.y.toString());
