Getting "TypeError: Unable to draw graphic (geometry:null, symbol:null): _e is null "
2485
10-29-2012 06:46 AM
SunilPalkar
Hello All,
I am getting an error..
http://serverapi.arcgisonline.com/jsapi/arcgis/3.2/js/esri/layers/FeatureLayer.js
Line 19"
I am using ArcGIS server 10.1 and JSAPI 3.2. I have 3 to 4 feature layers and I want to make TOC similar to the example here
The code is
 var map, baseMapLayer, featureLayer,t_layer,o_layer,newslayer,music_layer;
    var baseMapUrl = "https://server.arcgisonline.com/ArcGIS/rest/services/World_Topo_Map/MapServer";
    var other_url = " http://my server:6080/arcgis/rest/services/type/MapServer/2";
    var news_url = " http://my server:6080/arcgis/rest/services/type/MapServer/3";
    var music_url = " http://my server:6080/arcgis/rest/services/type/MapServer/4";
    function init() {
     var initExtent = new esri.geometry.Extent({
          "xmin": -16390544.849242661,
          "ymin": 1576883.9502372155,
          "xmax": -6606605.228742701,
          "ymax": 7447247.722537191,
          "spatialReference": {
            "wkid": 102100
      //extent = esri.geometry.geographicToWebMercator(initExtent);
      map = new esri.Map("map", {extent: initExtent});
      dojo.connect(featureLayer, "onLoad", function() {
        dojo.connect(map, "onZoomEnd", function() {
          featureLayer.setMaxAllowableOffset(maxOffset(map,1));
      dojo.connect(map, "onLoad", mapLoaded);
      dojo.connect(map,"onUpdateStart",function(){
        esri.show(dojo.byId("status"));
      dojo.connect(map,"onUpdateEnd",function(){
        esri.hide(dojo.byId("status"));
      // base map
      baseMapLayer = new esri.layers.ArcGISTiledMapServiceLayer(baseMapUrl);
      map.addLayer(baseMapLayer);
     // for other layer
    o_layer = new esri.layers.FeatureLayer(other_url);
    map.addLayer(o_layer);
   // for new layer
    newslayer = new esri.layers.FeatureLayer(news_url);
    map.addLayer(newslayer);
 //for music layer
    music_layer = new esri.layers.FeatureLayer(music_url);
    map.addLayer(music_layer);
    function mapLoaded() {
      //resize the map when the browser resizes
      dojo.connect(dijit.byId('map'), 'resize', map,map.resize);
      var maxOffset = function maxOffset(map, pixelTolerance) {
        return Math.floor(map.extent.getWidth() / map.width) * pixelTolerance;
    function toggleLayer(val){
        //alert('val '+val.name);
        if(val.name === 'checkOL'){
        o_layer.visible ? o_layer.hide():o_layer.show();
      else if(val.name === 'checkNL'){
        newslayer.visible ? newslayer.hide():newslayer.show();
      else if(val.name === 'checkML'){
         music_layer.visible ? music_layer.hide(): music_layer.show();
    dojo.addOnLoad(init);
  </script>
</head>
<body class="claro">
  <div data-dojo-type="dijit.layout.BorderContainer" data-dojo-props="design:'headline',gutters:false"  style="width: 100%; height: 100%; margin: 0;">
    <div data-dojo-type="dijit.layout.ContentPane" data-dojo-props="region:'right'" style="width:200px;">
    <label for="checkOL">Other Layer</label>
     <input data-dojo-type="dijit.form.CheckBox" checked="o_layer.layer.visible" name="checkOL" onChange="toggleLayer(this);"/>
     <br />
      <label for="checkNL">News Layer</label>
     <input data-dojo-type="dijit.form.CheckBox" checked="newslayer.layer.visible" name="checkNL" onChange="toggleLayer(this);"/>
     <br />
      <label for="checkML">Music Layer</label>
     <input data-dojo-type="dijit.form.CheckBox" checked="music_layer.layer.visible" name="checkML" onChange="toggleLayer(this);"/>
    </div>
    <div id="map" data-dojo-type="dijit.layout.ContentPane" data-dojo-props="region:'center'" style="border:1px solid #000;padding:0;">
      <span id="status" style="position: absolute; z-index: 100; right: 5px; top: 5px;">
        Loading...
      </span>
    </div>
  </div>
</body>
</html>
Please check the screen shot [ATTACH=CONFIG]18799[/ATTACH]
I searched on Google  and called support but they unable to resolve this error message.
So any help will be highly appreciated..
Thank you..
