************* getLayersVisibleAtScale does not work *************
1763
08-20-2013 07:38 AM
yanivarazi
hi,
I am using javascript api ver 3.6.
I have 2 layers, one base and one dynamic.
The getLayersVisibleAtScale does not work at all.
I manually hide my dynamic layer and see it gone on the screen, but i still get 2 layers objects and .
var layers = map.getLayersVisibleAtScale(  map.getScale() );
can you please help me  ?
thanks
yaniv
derekswingley1
It's not clear from our documentation, but the purpose of getLayersVisibleAtScale is to determine whether or not a layer's min and max scale would cause a layer to be visible or not. If you want to know whether or not a layer is currently shown on the map, do what you're doing and check layer.visible. If both are true, the layer is currently displayed on the map.
yanivarazi
Thank you for your reply.
yanivarazi
Drilling down to layers, how do i checklayer.layerInfos item in the current extent  ?
