GeometryService Project method...problem
959
10-26-2013 02:32 PM
ErikEklund1
Hello again!
I recently wrote about trying to convert X and Y coordinates (in RT90) to lat and lng.
Ken Buja helped me a lot by showing me a modified version of the "Project a point" sample which uses a GeometryService.
I got most of it to work and now I'm trying to simplify and strip down the code do for me to use when doing an API call.
But I'm stuck.... I get an error saying that the project method is undefined.
Does anyone see in the code below if I somehow need to change my arguments when calling the Project method of the esri.tasks.GeometryService class?
As always, help is very much appreciated!
I'm a newbie.... you might have figured out that already...:)
Thanks for your time
/Erik
require("esri.SpatialReference");
require("esri.tasks.GeometryService");
require("esri.tasks.ProjectParameters");
gsvc = new esri.tasks.GeometryService("http://tasks.arcgisonline.com/ArcGIS/rest/services/Geometry/GeometryServer");
function projectToLatLong() {
  var outSR = new esri.SpatialReference(4326);
  var inputpoint =  new esri.geometry.Point(1630111/*Y-test coord*/,6570898/*X-test coord*/, new esri.SpatialReference({ wkid: 3021 }));
  var params = new esri.tasks.ProjectParameters();
      params.geometries = [inputpoint];
      params.outSR = outSR;
      gsvc.project(params, function(projectedPoints) {
      pt = projectedPoints[0];
      return(pt.Y.toFixed(5),pt.X.toFixed(5));
