Geocoder Widget without a Map?
992
01-25-2013 06:05 AM
RichardBetts
Hi
Would it be possible to use the Geocoder widget without actually having a map object/map div on the page?
I've had to add a hidden map to the page for the time being but ideally I would like to avoid this.
I can see the map parameter is always required in the constructor but just wondering if there is a way to get around this or pass a reference to some kind of dummy map?
Richard
