Geocode CSV in JavaScript
10108
12
09-05-2014 07:43 AM
HeathAnderson
I am trying to geocode a list of addresses from a CSV.  I know that there is a drag and drop option that works well if you have lat long, but I only have addresses.  I want my coworkers to be able to save an xls as a csv then in the JS app browse to the CSV and run the gp model or drag and drop the csv into the map and kickoff the gp tool.  The service is upload enabled, but I am struggling getting the correct code down.  Has anyone done this before where they can point me in the correct direction.
Cheers,
Heath
PaulCrickard1
This uses Leaflet.js and makes an AJAX call to your GIS Service on ArcServer. Just change the URL to the location of your service. You can drag the textfile to the map and it will put markers on the map. And change the map center coordinates so it is where you want to be. Mine is in Albuquerque. This uses Drag and Drop functionality in HTML5 so you need a new browser - just use chrome.
My address file looks like this:
7520 Corona Ave NE
600 2nd St NW
6200 Paseo Del-Norte
3805 Northern Blvd NE
3701 Constitution Ave NE
320 Yale Boulevard SE
6001 Lomas Blvd NE
My HTML File:
<html>
<head>
  <title></title>
<link rel="stylesheet" href="http://cdn.leafletjs.com/leaflet-0.7.2/leaflet.css" />
<style>
#map{
height: 100%;
width:100%;
</style>
</head>
<body>
<script src="http://cdn.leafletjs.com/leaflet-0.7.2/leaflet.js"></script>
<div id="map" ></div>
<script>
var map = L.map('map',
center: [35.10418, -106.62987],
zoom: 9
L.tileLayer('http://{s}.tile.osm.org/{z}/{x}/{y}.png').addTo(map);
  function handleFileSelect(evt) {
    evt.stopPropagation();
    evt.preventDefault();
    var files = evt.dataTransfer.files; // FileList object.
    var reader = new FileReader();
    reader.onload = function(event) {
var temp=event.target.result;
var text=temp.replace( /\n/g, "," );
var c=text.split(",");
for(i=0;i<c.length;i++){
url1="http://YourDomain/ArcGIS/rest/services/AddressLocator/GeocodeServer/findAddressCandidates?Street=";
url2=String(c);
url3="&outFields=&outSR=4326&f=pjson";
url=url1.concat(url2,url3);
var xhReq = new XMLHttpRequest();
xhReq.open("GET", url, false);
xhReq.send(null);
var serverResponse = xhReq.responseText;
var d=JSON.parse(serverResponse);
if(typeof d.candidates[0] == 'undefined'){alert("error in address: "+url2);}
else{
L.marker([parseFloat(d.candidates[0].location.y),parseFloat(d.candidates[0].location.x)]).addTo(map).bindPopup(url2);
     var s = reader.readAsText(files[0],"UTF-8");
  function handleDragOver(evt) {
    evt.dataTransfer.dropEffect = 'copy'; // Explicitly show this is a copy.
  // Setup the dnd listeners.
  var dropZone = document.getElementById('map');
  dropZone.addEventListener('dragover', handleDragOver, false);
  dropZone.addEventListener('drop', handleFileSelect, false);
</script>
</body>
</html>
TracySchloss
Honored Contributor
I don't believe ESRI licensing allows batch geocoding in this manner.  That is part of an ArcOnline subscription.
JeffJacobson
This document describes what you are allowed to do with free vs. paid ArcGIS Online Geocode services. If you are using your own geocoding services then, of course, this does not apply to you.
Another alternative is the MapQuest Open Geocoding API Web Service.
TracySchloss
Honored Contributor
It sounds like a bit of a gray area.  If you aren't keeping the results beyond the session, then are you meeting the definition of 'batch'?  For myself, I have used the geocoder just as a means for getting the map focused to a particular area.
It might be OK in this scenario, but of course the next request from the user could be 'now I want to keep what I'm seeing' which just crosses over to 'not OK' without use of a subscription.
JeffJacobson
It looks like the free version only allows one address per request.
JeffJacobson
Here's a CSV-Reader JavaScript library that will allow the web browser to read the CSV file and convert it into JavaScript objects or arrays.
HeathAnderson
I am not sure that I clearly defined my problem.  I have a Geocode service running on our GIS Server in addition to a model that uses that same Geocode Service but creates an output shapefile and CSV table with matched addresses.  I want my coworkers to be able to click a button browse to a CSV with "Name", "Address", "City", "State", and "ZIP" as the column headers, click ok and the Geocoder Service will run.  This is what i have found from the REST API help page
Syntax:
{ "records"  : [ { "attributes" : {"<OBJECTID>" : "<OID11>","<field1>" : "<value11>", "<field2>" : "<value12>", "<field3>" : "<value13>"} }, { "attributes" : {"<OBJECTID>" : "<OID21>","<field1>" : "<value21>", "<field2>" : "<value22>", "<field3>" : "<value23>"} } ] }
Example 1:
{ "records": [ { "attributes": { "OBJECTID": 1, "STREET": "440 Arguello Blvd", "ZONE": "94118" } }, { "attributes": { "OBJECTID": 2, "STREET": "450 Arguello Blvd", "ZONE": "94118" } } ] }
Do I need to create an input type as file, assign it to variable and then pass in the variable as the input parameters?
PaulCrickard1
7520 Corona Ave NE
600 2nd St NW
6001 Lomas Blvd NE
My HTML File:
<html>
<head>
  <title></title>
<style>
#map{
height: 100%;
width:100%;
</style>
</head>
<body>
<script>
zoom: 9
url2=String(c);
xhReq.send(null);
else{
</script>
</body>
</html>
HeathAnderson
Works great, thank you.
Took a while to figure out that you can't have <!DOCTYPE html> on your page.  You must either delete it or comment it out.  Does you know why this is?  The page still functions correctly on IE, Chrome, and Firefox.
PaulCrickard1
Don't know why <!DOCTYPE html> doesn't work. It is supposed to sit above the <html> tag and tell the browser it is HTML 5.
Glad it works for you.
