Geocode and Pushpin Java API
1051
04-19-2012 12:14 PM
akashmagoon
I have this code and i want the add a x and y coordinate locator so you can add a pushpin at that point.
Also how do you have pushpins. I saw some of the samples on this website, but what code do you add a pushpin. How do you make it popup.
I have seen a x y coordinate locator in one sample, and a pushpin in another. I want to combine it to this code:
<!DOCTYPE HTML PUBLIC "-//W3C//DTD HTML 4.01//EN" "http://www.w3.org/TR/html4/strict.dtd">
<html>
  <head>
    <meta http-equiv="Content-Type" content="text/html; charset=utf-8"/>
    <meta http-equiv="X-UA-Compatible" content="IE=7,IE=9" />
    <!--The viewport meta tag is used to improve the presentation and behavior of the samples
      on iOS devices-->
    <meta name="viewport" content="initial-scale=1, maximum-scale=1,user-scalable=no"/>
    <title>Display Multiple ArcGIS Online Services</title>
    <link rel="stylesheet" type="text/css" href="http://serverapi.arcgisonline.com/jsapi/arcgis/2.8/js/dojo/dijit/themes/claro/claro.css">
    <style>
      html, body { height: 100%; width: 100%; margin: 0; padding: 0; }
      #map{padding:0;}
    </style>
    <script type="text/javascript">var djConfig = {parseOnLoad: true};</script>
    <script type="text/javascript" src="http://serverapi.arcgisonline.com/jsapi/arcgis/?v=2.8"></script>
      dojo.require("esri.map");
      dojo.require("dijit.form.Button");
      dojo.require("dijit.layout.BorderContainer");
      dojo.require("dijit.layout.ContentPane");
      dojo.require("esri.dijit.BasemapGallery");
      dojo.require("dijit.Menu");
      var map;
      var basemapGallery;
      function init() {
        var initExtent = new esri.geometry.Extent({"xmin":-14628212,"ymin":714227,"xmax":7718305,"ymax":9832858,"spatialReference":{"wkid":102100}});
        map = new esri.Map("map",{extent:initExtent});
        basemapGallery = new esri.dijit.BasemapGallery({
          showArcGISBasemaps: true,
          map: map
        dojo.connect(basemapGallery,"onLoad",function(){
         dojo.forEach(basemapGallery.basemaps, function(basemap) {
          //Add a menu item for each basemap, when the menu items are selected
          dijit.byId("basemapMenu").addChild(new dijit.MenuItem({
            label: basemap.title,
            onClick: dojo.hitch(this, function() {
              this.basemapGallery.select(basemap.id);
        dojo.connect(map, 'onLoad', function(theMap) {
          //resize the map when the browser resizes
          dojo.connect(dijit.byId('map'), 'resize', map,map.resize);
    dojo.addOnLoad(init);
    </script>
  </head>
  <body class="claro">
     <div dojotype="dijit.layout.BorderContainer" design="headline" gutters="false"
    style="width: 100%; height: 100%;">
      <div id="map" dojotype="dijit.layout.ContentPane" region="center">
        <div style="position:absolute; right:50px; top:10px; z-Index:99;">
          <button id="dropdownButton" label="Basemaps"  dojoType="dijit.form.DropDownButton">
            <div dojoType="dijit.Menu" id="basemapMenu">
              <!--The menu items are dynamically created from basemaps-->
            </div>
          </button>
        </div>
      </div>
    </div>
  </body>
</html>
Thanks for the help
akashmagoon
I have seen a project a point sample on the JAVA SAMPLE Page API.
How can take the project a point idea from
http://help.arcgis.com/en/webapi/jav...l_project.html
and put it in my code so that when i dont have a marker there, it projects the coordinates.
Heres my code:
<!doctype html>
<html lang="en">
<head>
<meta charset="utf-8">
<title></title>
<link rel="stylesheet" href="http://serverapi.arcgisonline.com/jsapi/arcgis/2.5/js/dojo/dijit/themes/tundra/tundra.css">
<link rel="stylesheet" href="http://serverapi.arcgisonline.com/jsapi/arcgis/2.5/js/esri/dijit/css/Popup.css">
<style>
#map{ margin: 0; padding: 0; }
</style>
<script>var dojoConfig = { parseOnLoad: true };</script>
<script src="http://serverapi.arcgisonline.com/jsapi/arcgis/?v=2.5"></script>
<script>
var map;
function init() {
var initExtent = new esri.geometry.Extent({"xmin":-13114922,"ymin":-5500000,"xmax":9292585,"ymax":10351408, "spatialReference":{"wkid":102100}});
var basemap = new esri.layers.ArcGISTiledMapServiceLayer("http://server.arcgisonline.com/ArcGIS/rest/services/World_Topo_Map/MapServer");
map.addLayer(basemap);
dojo.connect(map, "onLoad", function() {
var points = {
"points": [[-122.63,45.51],[-122.56,45.51],[-122.56,45.55],[-122.62,45.00],[77,19]],
"spatialReference": ({ "wkid": 4326 })
var mp = new esri.geometry.Multipoint(points);
var wm_mp = esri.geometry.geographicToWebMercator(mp);
var sms = new esri.symbol.SimpleMarkerSymbol();
var infoTemplate = new esri.InfoTemplate("Bob","Lives in the USA");
var graphic = new esri.Graphic(wm_mp, sms, '', infoTemplate);
map.graphics.add(graphic);
dojo.connect(map.graphics, "onMouseOver", function(evt) {
var g = evt.graphic;
map.infoWindow.setContent(g.getContent());
map.infoWindow.setTitle(g.getTitle());
map.infoWindow.show(evt.screenPoint,map.getInfoWindowAnchor(evt.screenPoint));
dojo.connect(map.graphics, "onMouseOut", function() {map.infoWindow.hide();} );
dojo.ready(init);
</script>
</head>
<body class="tundra">
<div data-dojo-type="dijit.layout.BorderContainer"
data-dojo-props="design:'headline',gutters:false"
style="width: 100%; height: 100%; margin: 0;">
<div id="map"
data-dojo-type="dijit.layout.ContentPane"
data-dojo-props="region:'center'">
</div>
</div>
</body>
</html>
