Geocode Address then Buffer
2059
08-01-2014 11:58 AM
jaykapalczynski
Honored Contributor
I am trying to Geocode an Address then Buffer that address....from there I want to use that buffered graphic for further queries...
I can get the Geocode to work but stuck on getting the Buffer code to create the buffered graphic of which I need to use its geometry to run further queries..
Am I way off here?
// GEOCODER START===========================================================================================
var x = "";
var y = "";
  var geocoder = new Geocoder({
   arcgisGeocoder: {
  placeholder: "4010 West Broad St, RIchmond, Virginia"
   autoComplete: true,
   map: app.map,
  }, dom.byId("search"));
  geocoder.startup();
    geocoder.on("select", showLocation);
    geocoder.on("clear", removeSpotlight);
        function showLocation(evt) {
          //app.map.graphics.clear();
          var point = evt.result.feature.geometry;
  x = point.x
  y = point.y
          var symbol = new SimpleMarkerSymbol().setStyle(
            SimpleMarkerSymbol.STYLE_circle).setColor(
            new Color([255,0,0,0.5])
          var graphic = new Graphic(point, symbol);
          app.map.graphics.add(graphic);
// ATTAMPT TO BUFFER THE RETURNED LOCATION
  var paramsGC = new BufferParameters();
  paramsGC.geometries  = graphic;
  paramsGC.distances = [ .5 ];
  //paramsGC.bufferSpatialReference = new SpatialReference({wkid: 26917});
  paramsGC.outSpatialReference = app.map.spatialReference;
  paramsGC.unit = GeometryService.UNIT_STATUTE_MILE;
        // geometry service that will be used to perform the buffer
        var geometryServiceGC = new GeometryService("https://tasks.arcgisonline.com/ArcGIS/rest/services/Geometry/GeometryServer");
  geometryServiceGC.buffer(paramsGC);
        geometryServiceGC.on("buffer-complete", function(result){
          // draw the buffer geometry on the map as a map graphic
          var symbol2 = new SimpleFillSymbol(
            SimpleFillSymbol.STYLE_NULL,
            new SimpleLineSymbol(
              SimpleLineSymbol.STYLE_SOLID,
              new Color([105,105,105]),
            ),new Color([255,255,0,0.25])
          var bufferGeometryGC = result.geometries[0]
          var graphicGC = new Graphic(bufferGeometryGC, symbol2);
          app.map.graphics.add(graphicGC);
// GEOCODER END===================================================================================================
jaykapalczynski
Honored Contributor
This is the code...
  1. Geocoder
  2. Then Draw Buffer around Gocoded Result
  3. Then Query 1 Features and return their respective Geometry
// GEOCODER START =================================================================
var x = "";
var y = "";
   arcgisGeocoder: {
  placeholder: "Dallas, Texas"
   autoComplete: true,
   map: app.map,
  geocoder.startup();
          var pointGC = evt.result.feature.geometry;
  x = point.x
  y = point.y
          //app.map.infoWindow.setTitle("Search Result");
          //app.map.infoWindow.setContent(evt.result.name);
          //app.map.infoWindow.show(evt.result.feature.geometry);
        var symbol_historicArchitectureGC = new SimpleFillSymbol(
            "solid",
            new SimpleLineSymbol("solid", new Color([0,76,153]), 2),
            new Color([0,128,255,0.5])
        flVAFWIS_historicArchitecture.setSelectionSymbol(symbol_historicArchitectureGC);
        // Add the Feature Layer To Map
        app.map.addLayer(flVAFWIS_historicArchitecture);
  paramsGC.geometries  = [ pointGC ];
          var symbol22 = new SimpleFillSymbol(
              new Color([247,5,38]),
          var graphicGC = new Graphic(bufferGeometryGC, symbol22);
          var query_historicArchitectureGC = new Query();
          query_historicArchitectureGC.geometry = bufferGeometryGC;
    // Select the Points within the Buffer and show them
          flVAFWIS_historicArchitecture.selectFeatures(query_historicArchitectureGC, FeatureLayer.SELECTION_NEW, function(results){
} // End function showLocation(evt) {
// GEOCODER END =====================================================================
jaykapalczynski
Honored Contributor
I tried to use the variable Point as well but nothing
  paramsGC.geometries  = point;
jaykapalczynski
Honored Contributor
Think I got it... forgot the  [ ]
paramsGC.geometries  = [ point ];
jaykapalczynski
Honored Contributor
This is the code...
  1. Geocoder
var x = "";
var y = "";
   arcgisGeocoder: {
   autoComplete: true,
   map: app.map,
  geocoder.startup();
  x = point.x
  y = point.y
            "solid",
TimWitt2
Jay,
put the following outside of your showLocation function:
var point;
and then remove the var in front of point inside your showLocation function, so that it looks like this:
now it should be global and ready to be used in your BufferParameters.
