FullPage.js and dojo event handling
727
09-13-2016 05:22 AM
MatejSkerjanc
I've created a web app which uses fullPage.js. If i traverse from one slide/section to another map stops catching my clicks, but initially it works, whereas jQuery catches map clicks without a problem. Probably not many of you use fullPage so this is a long shot but still worth trying. Has anyone tried it and dojo handlers worked flawlessly?
Best regards,
Matej
