Formatting an InfoWindow
1308
04-23-2013 11:14 AM
KenBuja
MVP Esteemed Contributor
In my application, I have a map service containing many different layers, each containing many different fields. In the mxd file that created the service, we have hidden all the fields in each layer that don't need to be shown. When the user clicks on the map, I run the IdentifyTask and I'd like to show the user which layer is being represented in the InfoWindow when there are results from different layers.
Currently, using the code
var deferred = identifyTask.execute(identifyParams);  deferred.addCallback(function (response) {     // response is an array of identify result objects         // Let's return an array of features.     return dojo.map(response, function (result) {         var feature = result.feature;         feature.attributes.layerName = result.layerName;         //var infoTemplate = new esri.InfoTemplate('${result.layerName}', "${*}");         var infoTemplate = new esri.InfoTemplate("test", "${*}");         infoTemplate.setTitle("testing");         feature.setInfoTemplate(infoTemplate);     }     return feature; });
gives me an InfoWindow with the layer name appended to the end of the list of fields. How can I format the infoWindow so that the layerName is at the top of the field list? Setting the title doesn't seem to have any effect.
[ATTACH=CONFIG]23729[/ATTACH]
KenBuja
With a little more digging, I solved it with this code
var sp = feature.attributes; contentString += "<b>" + result.layerName + "</b>";  for (x in sp) {     contentString += "<br/>";     contentString += x + ": " + feature.attributes; }
KenBuja
I'm making some progress on this by getting the attributes from the graphic. However, I'm running into a problem with the object that's returned from the line "features.attributes". The line
returns this object
Object { OBJECTID="5", County Name= "Palm Beach County",  more...}
However, when I try to loop through sp with the code
contentString += result.layerName;
for (x in sp) {
    contentString += x;
the value for x is just the attribute name, not the attribute and its value. That code results in a contentString with a value of
"Study Counties - SEFCRI Region Boundary<br/>OBJECTID<br/>County Name<br/>County Seat"
How can I parse out the attributes object correctly?
KenBuja
