FloorFilter: press "zoom to" button programmaticaly
745
10-03-2025 08:01 AM
abru62
Hi JavaScript SDK Community,
I wrote successfully a MapViewer with a preconfigured (facility, level) FloorFilter.
The WebMap is shown, the FloorFilter shows the correct facility and the correct floor.
But the WebMap stays at the initial view and zoom. I have to press the "zoom to" button in the FloorFilter to show the selected floor.
Is it possible to "press" the FloorFilter zoom button programmaticaly?
Many thanks for any hint.
Regards
Armin
JoelBennett
MVP Regular Contributor
Yes, you can use the undocumented method "_zoomToClicked" to simulate a click on the "Zoom to" button:
floorFilter._zomToClicked();
Note that because this is an undocumented feature, it may be changed or removed in a future version of the SDK without notice.
abru62
Unfortunately it does not work.
Console output is: FloorFilter._zoomToClicked is not a function
This is the code (JS SDK 4.33):
const FloorFilter = document.createElement("arcgis-floor-filter");
    FloorFilter.position = "top-left";
    FloorFilter.facility = facility;
    FloorFilter.level = floor;
    FloorFilter.longNames = false;
    viewElement.appendChild(FloorFilter);
    FloorFilter._zoomToClicked();
JoelBennett
I see...I thought you were using the widget, but you're actually using the map component.  I'm afraid I don't presently have any further advice in that case.
