Firefox 18 and Draw Toolbar
2060
8
02-04-2013 08:16 AM
MarcusBush
I'm working on an app using 3.3 of the API and uses a draw toolbar.
I noticed some bugs, I came to check the documentation to see if anything had changed and noticed the same bugs on the API sample page for draw toolbar:
http://help.arcgis.com/en/webapi/javascript/arcgis/samples/graphics_add/index.html
Poly lines and tooltips aren't showing up during the drawing process, and sometimes after the fact, as in the case of polyline.. you can go through the motions and sometimes see what should be the final result.
Anyone noticed this and have a possible fix or work-around?
Thanks in advance!
MarcusBush
Hoping a "Reply" moves this up..
ReneRubalcava
Esri Frequent Contributor
I tried this in FF 18.0.1 and I don't think I'm seeing what you're seeing. I can see Polylines and tooltips as I draw them. What version of FF are you seeing this in?
MarcusBush
FF 18.0.1 also, using the link I posted, after hitting buttons polyline, polygon, etc.  Same behavior in my app.
derekswingley1
Can you post some code to reproduce? I'm not able to see this with the draw toolbar sample.
MarcusBush
Derek,  I clicked your link and get the same behavior.  It must be something on my end.  I re-installed Firefox and still the same thing.  I now have a better direction to investigate, thank you two for trying it out.
JeffPace
tested in 19 working fine.  Any errors in Firebug?
MarcusBush
Forgive me, where did you get 19?  I'm still finding 18.0.1 as the latest.
JeffPace
beta channel
