FIPS map on server?
989
09-19-2012 03:15 AM
JozefKrchnavy
I'm creating application for selection counties and exporting FIPS. I used example with this layer (from samples):
new esri.layers.ArcGISDynamicMapServiceLayer("http://sampleserver1.arcgisonline.com/ArcGIS/rest/services/Specialty/ESRI_StateCityHighway_USA/MapSe...");
But this is not production server so there is no guarantee for availability. Is there a way to use this layer on own server? And if, what do I need to do.
Thank you!
Jozef
JohnGravois
i did a quick check and it looks like we have some demographic map services published on our production servers, but it doesn't look like the counties layers include FIPS.
http://services.arcgisonline.com/ArcGIS/rest/services/Demographics
if you have ArcGIS Desktop installed, the software comes with a generalized US Counties feature class (with FIPS) in the following location
..\ArcGIS\Desktop10.x\TemplateData\TemplateData.gdb\USA\counties
You could publish a new service with this data and use your own map service REST url instead.
