FeatureTable 4.30 failing to display grid
1746
08-02-2024 12:43 PM
Shingo-Ikeda
I have recently upgraded my JS API from 4.29.10 to 4.30 and I noticed that FeatureTable is no longer displayed. It shows the record counts at the top (i.e., LayerName (Total: 100 | Selection: 0)); however, the rest of the table is greyed out.
I have modified and removed all css components; however, it is still not displayed. Its associated feature data (from GeoJsonLayer) is displayed on map component.
I am using Angular and I am not clear if this is causing the issue.
Shingo Ikeda
Geospatial Data Scientist/Developer - Geographical Information Platform
Global Power Generation - Digital Satellite USA and Canada
Shingo-Ikeda
I was able to make it display when I updated stylesheet reference to 4.30 and changed the FeatureTable display to use viewChild as:
html:
<div id="tableWrapper" class="table-wrapper">
<div #tableContainer></div>
</div>
ts:
@ViewChild('tableContainer', { static: true }) private tableContainerEl!: ElementRef;
Shingo Ikeda
Shingo-Ikeda
Here is the example of the FeatureTable. In 4.29.10, it displays correctly.
Shingo Ikeda
Shingo-Ikeda
I am using "@angular/core": "16.2.12". @AndyGup, do you think this is something to do with Angular libraries that's causing the failure in the display?
Shingo Ikeda
Shingo-Ikeda
html:
</div>
ts:
Shingo Ikeda
